Hi Bill,
Try FLAGS = 0 early in your code.
Hi Bill,
Joe S
Thanks very much, your tip worked
FLAGS=0 Did the trick.
I've looked up the note on FLAGS=0 in the LCDOUT command page of the PBP manual and don't understand how it works?
1. If I cycle the power to the PIC, without 'FLAGS=0' all is OK.
2. If I re-set I get the missing lines problem unless the statement 'FLAGS=0' is included.
I thought the PIC executed the same code on re-set as on power-up?
Whatever, you help is much appreciated.
Regards Bill Legge
little deeper.... when you clear FLAGS value, the next LCDOUT will include the whole LCD initialization commands (1 line or more, 4 or 8 bits mode etc etc... see your LCD datasheet), then send your data.
You can do it manually with few LCDOUT, but since FLAGS-0 do the job, why messing with it euh?![]()
Just curious Bill, "reset" used in the first post, what do you mean by that, are you taking the mclr line low or doing a full power off scenario?
I ask because a power off that only browns out the LCD may be the entire problem. There will be times you do not want to use flags = 0 due to latency problems.
Joe S
The boards I'm using have a 10k resistor that normally holds MCLR high. The re-set button takes the MCLR pin direct to ground. The power is on all the time.
I have been lazy with LCDs and not bothered with the spec sheets - just use the PBP LCD commands.
FLAGS=0 has solved most of my problems but I still get the odd occasion when alternate lines of the LCD don't come to life.
I suspect that the proper way to fix this is some combination of FLAGS and the configuration brown-out settings. AND READ THE SPEC SHEETS!
I mostly use PIC16F877A and PIC18F8722 chips on Mikroelektronika boards for developement and move to Futurlec boards for the end product - all hobby stuff, no production.
Thanks for you interest.
Regards Bill Legge
