Here's an example of reading an analog voltage with a 12F683. I'll let you figure out the LED part...;}
@ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
DEFINE OSC 8 ' Internal 8MHz
DEFINE DEBUG_REG GPIO ' Define DEBUG port
DEFINE DEBUG_BIT 1 ' Set GPIO.1 as DEBUG serial output pin
DEFINE DEBUG_BAUD 9600 ' DEBUG baud rate = 9600 bps
DEFINE DEBUG_MODE 1 ' 1 = inverted, 0 = true
DEFINE ADC_BITS 10 ' 10-bit resolution
DEFINE ADC_CLOCK 5 ' Set clock source to Frc/16
DEFINE ADC_SAMPLEUS 50 ' Sample time in uS before A/D conversion is started
Quanta CON 1251 ' For 10-bit A/D +Vref = 5V : 5V/1023*256=1.251=Quanta
' PIN# NAME USE & CONNECTION
' 1 Vdd +5VDC power supply
' 2 GPIO.5 N/C (N/C = NO CONNECTION)
' 3 GPIO.4 N/C
' 4 GPIO.3 N/C
' 5 GPIO.2 N/C
' 6 GPIO.1 Serial output pin to PC serial port RX pin
' 7 GPIO.0 A/D input pin
' 8 Vss Power supply ground (also connect to DB-9 pin #5)
CMCON0 = 7 ' Disable comparator
ANSEL = %00000001 ' Set GPIO.0 to A/D
ADCON0.7 = 1 ' Right justify for 10-bit
TRISIO = %00000001 ' GP.1 = serial out, GPIO.0 = A/D in, rest outputs
OSCCON = %01110000 ' Internal 8MHz osc
ADval VAR WORD ' A/D conversion result
MAIN:
ADCIN 0, ADval ' Read A/D
ADval = ADval */ Quanta
DEBUG DEC ADval DIG 3,".",DEC3 ADval,"~"
PAUSE 200
GOTO MAIN
