LCDout Command w/ LCD 4x40 display
Results 1 to 26 of 26
    beto's Avatar
    beto Guest
    Default LCDout Command w/ LCD 4x40 display
    Hi!
    This lcd have 2 Enable lines (e1,e2), anyone know, how these lines to be handled by the pbp compiler?
    I buil this circuits but doesn't work ...
    Can helpme please? thanks ..... Friends
    code) look like this:
    DEFINE OSC 10
    DEFINE LCD_DREG PORTB
    DEFINE LCD_BIT 0
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 7
    DEFINE LCD_EREG PORTD
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 4
    DEFINE LCD_EBIT 6
    dsp var portd.5
    FLAGS = 0
    START:
    dsp = 0
    LCDOUT $FE,1 :PAUSE 500 : LCDOUT "SYSTEM 1" 'lcd upper
    dsp = 1
    LCDOUT $FE,1 :PAUSE 500 : LCDOUT "TWO SYSTEM" ' bottom lcd
    goto start
    DEFINE OSC 10
    DEFINE LCD_BIT 0
    DEFINE LCD_RSBIT 7
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 4
    DEFINE LCD_EBIT 6
    dsp var portd.5
    FLAGS = 0
    START:
    dsp = 0
    dsp = 1
    goto start
    by this code, you're saying that you using the full 8bit for data... right???
    1. Be sure you don't revert D0 to D7.
    2. IMO you must define a LCD_LINES 2. This is why you have 2 enable lines... BUT I'M REALLY NOT SURE... i just see it's a 4X40 LCD...
    3. What about if you play with the voltage on Vo pin??? Is at least you see some black square???
    4. AND you didn't set direction of your dsp PIN... TRISD.5=0
    5. You may need a startup delay (about .5 to 2 sec) at the begining.
    6. Maybe DEFINE LCD_DATAUS and DEFINE LCD_COMMANDUS defines may do something.
    beto's Avatar
    beto Guest
    Angry
    I have tried to change the LCD_EBIT definition on "Fly"
    @#UNDEFINE LCD_EBIT
    @#DEFINE LCD_EBIT 6
    LCDOUT $FE,1 :PAUSE 500 : LCDOUT "SYSTEM 1" : PAUSE 2000
    @#UNDEFINE LCD_EBIT
    @#DEFINE LCD_EBIT 5
    LCDOUT $FE,1 :PAUSE 500 : LCDOUT "TWO SYSTEM": PAUSE 2000
    but it does not work either
    beto's Avatar
    beto Guest
    Hi mister_e
    let me explain
    the code above works! but only in the first 2 lines of the lcd
    the problem is write data on botton lcd ,because I think that this
    LCD have two 2 x 40 display sharing only the data and rs/rw lines
    the other lines (e1 & e2) are for each part of LCD
    O.k. So what about the TRISD.5=0 ?? Can you monitor ENABLE lines to see if they're adress separately?
    beto's Avatar
    beto Guest
    I put long delay in the code and check with my logic probe to see changes
    and yes there are changes (using AND gates) but the lower part of lcd does not even work
    beto's Avatar
    beto Guest
    thanks Ingvar:
    Its exactly tha same circuit (enable2.bmp)
    ... can be that I need high speed devices since that the pics runs at 10Mhz? , because only 1 lcd is working w/ that schematcs
    No in this case, speed is not an issue. IMO, it's the *FLAGS* trick that you must place at the right place to initialize properly the LCD.
    OR the 2nd(bottom) lcd need specific addressing. What type of LCD are you using???
    What about if you revert ENABLE lines? Is now bottom one is working but not the top one ???
    Feb 2004
    Germany
    Beto
    You should definitely try what Steve has suggested
    to make sure both the controllers on the module are working properly.
    I guess the only problem is the initialisation of the second controller.
    PBP sends the "INIT" String automatically with the first LCDOUT command issued.
    As with your Hardware design only one of the two controllers will be enabled at a time, only one controller will be initialised.
    The workaround is the to "RESET" Flags.
    So at the beginning of your program (before your MainLoop starts)
    you should add:
    PAUSE 500
    DSP=0
    LCDOUT $FE,1
    PAUSE 500
    FLAGS=0
    DSP=1
    LCDOUT $FE,1
    see my posting in the FAQ section Ingvar has already mentioned:
    Click here
    B.T.W.
    here is another useful link:
    Click here
    regards
    Ralph
    beto's Avatar
    beto Guest
    The LCD is a Tianma TM404abcw6 model
    when I revert the ENABLE lines , what happens?
    the other part of the lcd respond, I mean;
    l-----------------------------------------l
    l 2 x40 lines upper part l < Controled by e1
    l 2 x40 lineslower part l< Controled by e2
    Feb 2004
    Germany
    Beto,
    may we assume you have got it working now?
    regards
    Raplh
    in case not can you try those lines...
    start:
    dsp=0
    lcdout $fe,$38 'lcd mode
    lcdout $fe,$0c 'lcd on
    lcdout $fe,1 'clear lcd
    lcdout "display 1"
    dsp=1
    lcdout "display 2"
    here: goto here
    beto's Avatar
    beto Guest
    At least!
    A lot of thank friends...
    the problem was, I try to use the enable2.bmp circuit (posted here) but I do not use a real inverter, I mean; i build the inverter circuit (IC 1A) using a low profile NPN transistor (2N3904) as inverter (I have used before and worked very well ) I don't know why in this circuit doesn't work?
    the solution?... replace it with a 'real' inverter (i.e. 7404 Series)
    and presto Is working....
    Thanks Again
    AHHHH damn
    What was your resistor value around your transistor ?!?
    beto's Avatar
    beto Guest
    10k for the base bias and 1k for the colector (emitter tied to GND)
    It have to work... in case not your 2n3904 don't have the great HFE... probably a die one :-)
    Have you try 1k for bias an 1k for the collector?
    beto's Avatar
    beto Guest
    Yes , Efectively changing to your values, the circuit works fine
    this 3904 do not have good AC Characteristics?
    With these val the base-emiter I is about 5mA and the 2N
    have a HFE about 70-100 (limiting Ic val to less of 10mA)
    I don't understand anything about teh HFE and resistors,
    in my schematic i only use 2 resistors.
    Well since we work in digital, common calculation is to multiply by ten the Base current needed.
    If 1K to the collector. Ic = 5/1000 = 5mA
    HFE = 70 (take the minimum to ensure...
    Ib= (Ic/HFE) * 10 = 0.7ma
    Rb = (5 - 0.7) / 0.7mA = 6k at minimum
    By the Maths, i figure that 5.6k, 5.1k or 4.7K as base resistor can also work.
    In many application you'll see 1k to base, 1k to collector too or same base value as collector one.
    Oke that's what i understand, only are you guys realy using a transistor?
    If you're not going to use the other inverter in this IC, why spend PCB space and $. Like the AND gate... if you have extra i/o, forget the AND gate and inverter stuff.
    beto's Avatar
    beto Guest
    MMhh.. Yes I have unused pic pins, How I can Integrate this circuit (and gate & inverter) in my program
    Thumbs down
    oops forget about me... i'm wrong in that issue. There's probably some tricks to do but... at this time i can't see how to remove all of them...
    BTW you can save the inverter stuff using another enable i/o.
    PAUSE 500
    Enable1 = 1
    Enable2 = 0
    Lcdout $Fe,1,"I'm on the first one"
    FLAGS=0
    Enable1 = 0
    Enable2 = 1
    Lcdout $Fe,1,"I'm on the second one"
    This have to work and it's suppose to be easy to figure out how to connect to the PIC.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  2. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 02:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
