xport code, have example, confused though
Results 1 to 15 of 15
    Feb 2005
    Toronto, Canada
    haven't hooked it up yet, so currently running at 0v
    not sure how to run something at 3.3v is there something like a 7805?
    and still no idea what USART is so I guess I'll do some reading.
    xport defualt is 9600, but it can be brought down.
    I'm excited to try this thing out, but I'm waiting for a breadboard compatible breakout board before I try it, rather than rush in and break something my first try.
    To run at 3.3 volt, yup you'll need a 3.3v voltage regulator. Now double check your specific datasheet to know if the PIC can run @3.3 volt without problem, case not, you may need to use a sort of level shifter between your PIC running @5volt and the Xport running @3.3v.
    USART is just another built-in PIC feature, listed in the datasheet. You will need to use HSERIN/HSEROUT + some DEFINEs all listed in the PBP manual.
    with 4MHz you can run the internal USART to have a really decent/accurate 9600 bauds.
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    Feb 2005
    Toronto, Canada
    thanks everyone! I'm going to muck around with all of this now!
    Sep 2005
    Campbell, CA
    You can get a 3.3V regulator. I use an LM3940
    You obviously haven't read section 12 of the 16F628 datasheet - where it describes the USART!
    There is no need to run the XPORT at a speed slower than 9600 baud.
    Charles Linquist
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
