Toggle command
Results 1 to 14 of 14
Thread: Toggle command
    Default Re: Toggle command
    Brilliant forum as usual just the answer I was looking for. I was about to start TOGGLING variable bits !!!
    Which is the smallest code to toogle a bit out of the ones you gave?
    Mode.0 = !Mode.0
    Mode.0 = NOT Mode.0
    Mode.0 = Mode.0 ^ 1
    Mode.0[0] = ~Mode.0[0]
    And an unrelated question about the STR modifier when recieving SERIAL2 data into an array.
    I use SKIP that's great and /STR 10 or whatever and it loads data into my array starting at array index[0]
    Can you make it start at a different point, say array index [10] without overwriting anything in the [0]-[9] positions?
    Not that I know of.
    You could save to data to another array and make bitX of one equal the other...
    Quote Originally Posted by retepsnikrep View Post
    As long as the offset into the array is always the same, you can just use STR MyArray[10]\10 and it will start adding data at that position without affecting data before or after that range.
    The offset must be a constant. Variables will not work inside the brackets.
    And the smallest code of the previous examples is either ! or NOT, which both compile to the exact same code.
    That is something good to know, but where have I missed this in the docs? Thanks Darrel!
    Although it doesn't give the exact example I showed above. The concepts are covered in the PBP3 manual section 7.6.
    In particular ... 7.6.2 and 7.6.3.
    It's good that it works with a constant, but what's the issue with variables, why can't it work with them?
    You can have variables for the Index pointer in arrays in general :?
    Is that going to be added in a future pbp upgrade, or is there some fundemental reason it's difficult/impossible to implement?
    Arrays with a variable index are evaluated at run-time to return/assign the value of that array location.
    Arrays with a constant index are evaluated at compile-time, and through "Constant Folding" is reduced to a scaler variable.
    As with any other scaler variable, it can be used as the start of an array.
    With a variable index, there's no way for the compiler to know you wanted the array location, instead of the value at that location.
    The language just doesn't allow for it.
    If the language was changed, it would break everyone's existing programs.
    Once again Darrell, thanks for the lesson!!!
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 20:52
  2. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  3. toggle command w/ multiple switches
    Last Post: - 15th February 2007, 17:47
  4. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 23:31
  5. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 18:57
