Another I2C Slave Routine Problem
Results 1 to 5 of 5
    Default Another I2C Slave Routine Problem
    Hello Guys,
    I spent a few days reading the forum, checking and double checking, and I hit a dead end...
    I have two PICs 16F88, one master and one slave... I'm able to tell the slave to do something, but I'm not able to read a byte from the slave...
    This is the master, pretty simple:
    ' Master
    @ device pic16f88, intrc_osc_noclkout	' system clock options
    @ device pic16f88, wdt_on			' watchdog timer
    @ device pic16f88, pwrt_on			' power-on timer
    @ device pic16f88, mclr_off			' master clear options (internal)
    @ device pic16f88, protect_off		' code protect off
    DEFINE OSC 8
    OSCCON = %01110001 '8mhz
    CMCON = 7
    ADCON1 = 0 ' Disable A/D converter
    ADCON0 = 0
    ANSEL = 0 ' all analog pins to digital
    DEFINE I2C_HOLD 1
    DEFINE I2C_SLOW 1
    scl VAR PORTB.4      ' i2c clock input
    sda VAR PORTB.1     ' i2c data input
    valor VAR BYTE      ' value to read
    LED VAR PORTA.6
            valor = 0
    '        I2CWrite sda, scl, $01, [31]
    '        High LED
    '        Pause 100
    '        I2CWrite sda, scl, $01, [30]
    '        Low LED
    '        Pause 100
            I2CRead sda, scl, $01, [valor]
            IF (valor = 24) Then
               High LED
    	 Pause 500
                 Low LED
            EndIF
    		GoTo main
    And, this is the slave:
    ' Slave
    DEFINE OSC 8
    CMCON = 7
    ADCON0 = 0
    DEFINE I2C_HOLD 1
    DEFINE I2C_SLOW 1
    SSPIF VAR PIR1.3	' SSP (I2C) interrupt flag
    BF VAR SSPSTAT.0	' SSP (I2C) Buffer Full
    R_W VAR SSPSTAT.2	' SSP (I2C) Read/Write
    D_A VAR SSPSTAT.5	' SSP (I2C) Data/Address
    CKP VAR SSPCON.4	' SSP (I2C) SCK Release Control
    SSPEN VAR SSPCON.5	' SSP (I2C) Enable
    SSPOV VAR SSPCON.6	' SSP (I2C) Receive Overflow Indicator
    WCOL VAR SSPCON.7	' SSP (I2C) Write Collision Detect
    I2Caddress CON 1	' Make our address 1
    SSPADD = I2Caddress ' Set our address
    SSPCON = $36 		' Set to I2C slave with 7-bit address
    LEDR VAR PORTA.3 ' LED 1
    LEDL VAR PORTB.3 ' LED 2
    BZR  VAR PORTA.7 ' Buzzer
    RL6  VAR PORTB.6 ' Relay 1
    RL12 VAR PORTB.5 ' Relay 2
    datain VAR BYTE		' Data in
    dataout VAR BYTE	' Data out
    GoTo boot
    i2cslave: ' I2C slave subroutine
              SSPIF = 0
              IF R_W = 1 Then i2crd ' Read data from us
              IF BF = 0 Then i2cexit ' Nothing in buffer so exit
              IF D_A = 1 Then i2cwr ' Data for us (not address)
              IF SSPBUF != I2Caddress Then i2cexit ' Clear the address from the buffer
              GoTo i2cexit
    i2cwr: ' I2C write data to us
           datain = SSPBUF ' Put data into array
           GoTo i2cexit
    i2crd: ' I2C read data from us
           SSPBUF = dataout ' Get data from array
           CKP = 1 ' Release SCL line
           GoTo i2cexit ' That's it
    i2cexit:
             SSPOV = 0
             WCOL = 0
    boot:
    Pause 500
    High RL12
    High RL6
          dataout = 24
          IF SSPIF = 1 Then
             GoSub i2cslave
             Toggle LEDL
          EndIF
          IF datain = 121 Then	' on 12v
            High RL12
          EndIF
          IF datain = 120 Then	' off 12v
             Low RL12
          EndIF
          IF datain = 61 Then	' on 6v
             High RL6
          EndIF
          IF datain = 60 Then	' off 6v
             Low RL6
          EndIF
          IF datain = 31 Then	' on buzer
             High BZR
          EndIF
          IF datain = 30 Then	' off buzzer
             Low BZR
          EndIF
          GoTo main
    Could someone please through some light over here... I really don't know what else to check...
    Thanks a lot!
    Daniel.
    Wink
    Hi, Daniel
    Did you had a look to the " I2cMaster " and " I2CSlave " example programs given on Melabs site ???
    looks something is read from the slave chip.
    Yes, all my code is based on those two files, and those two files don't work out of the box... I mean, the I2C routines don't work without adding a few more lines... And, I'm still in the dark...
    Anyone willing to share ideas or a working code?
    Thanks!
    Daniel.
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  4. I2C slave
    Last Post: - 16th March 2008, 03:46
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 13:55
