Variable in array
Results 1 to 6 of 6
    Dec 2007
    Finland
    Post Variable in array
    I'm trying to increase LCD refresh rate by doing SPI commands without using SHIFTOUT. There seems to be quite big improvement between code #1 and code #2.
    Code #1: Lcd_CLK high time is 3.6us
    Code #2: Lcd_CLK high time is 0.8us
    This speed increasement is big and you can really notice it visually
    Code #1
        SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [FC(0),FC(1),FC(2),FC(3),FC(4),FC(5)]
    Code #2
        Lcd_SDA = FC.0(7) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(6) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(5) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(4) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(3) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(2) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(1) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(0) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(15) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(14) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(47) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(46) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(45) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(44) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(43) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(42) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(41) : Lcd_CLK = 1 : Lcd_CLK = 0
        Lcd_SDA = FC.0(40) : Lcd_CLK = 1 : Lcd_CLK = 0
    Because Code #2 is quite long (48 lines) and consumes memory, I tried to make it with loops but there I faced big problems.
    I tried many different ways but never managed to get it work as Code #2.
        for i = 0 to 5
            k=7+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
            k=6+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
            k=5+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
            k=4+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
            k=3+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
            k=2+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
            k=1+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
            k=0+8*i : Lcd_SDA = FC.0[k] : Lcd_CLK = 1 : Lcd_CLK = 0
        next i
        for i = 0 to 5
            Lcd_SDA = FC.0[7+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[6+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[5+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[4+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[3+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[2+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[1+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[0+8*i] : Lcd_CLK = 1 : Lcd_CLK = 0
        next i
        for k = 0 to 5
            for i = (8+(8*k)) to (1+(8*k)) step -1
                j = i-1
                Lcd_SDA = FC.0(j) : Lcd_CLK = 1 : Lcd_CLK = 0
            next i
        next k
    (Variables i, j and k are bytes)
    I have read Melanies guide about Bits, Byte Words and Arrays, which tells how to you can reference to Arrays, etc...
    http://www.picbasic.co.uk/forum/show...17&postcount=1
    but it didn't help me too much. I have understood that variable in array is OK, am I wrong?
    -Gusse-
    May 2008
    Italy
    Gusse, this one should be better:
    for i = 0 to 40 step 8
            Lcd_SDA = FC.0[7+i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[6+i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[5+i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[4+i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[3+i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[2+i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[1+i] : Lcd_CLK = 1 : Lcd_CLK = 0
            Lcd_SDA = FC.0[0+i] : Lcd_CLK = 1 : Lcd_CLK = 0
        next i
    Al.
    Dec 2007
    Finland
    Post No solution yet...
    Hi Al,
    Your code worked a bit better but no as Code #2.
    Even code below won't run as Code #2. I wounder why? Only difference is that there is a variable in array. And why i = 0-7 is OK, but next are not??
        i=7 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=6 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=5 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=4 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=3 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=2 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=1 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=0 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
        i=15 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0 '<- Stop working
        i=40 : Lcd_SDA = FC.0(i) : Lcd_CLK = 1 : Lcd_CLK = 0
    It seems that 1st character (1st 8 bits) are OK, but next charaxters 1-5 are not working (shows only blanck screen at those places).
    -Gusse-
    May 2008
    Italy
    you have an extra operation to do in this code (i=7:..), while in code 2 you don't do.
    Al.
    Dec 2007
    Finland
    Post
    To my understanding these two codes should be as equal as possible. One is using a constant, the other variable (i).
    This extra operation i=7 shouldn't be a problem if arrays support variable(s).
    -Gusse-
    Dec 2007
    Finland
    Red face Me Stupid!
    Now when I re-opened this problematic project, it was very clear to me what was wrong. It was too obvious and I can only say "Me Stupid!".
    If I have defined a new variable for loop, something else than i, j or k (which were used in other part of the code) then I would never faced the problem.
    All codes posted under this topic are working well.
    Thanks Al for your help, I appreciate it a lot!
    -Gusse-
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. How to saparate variable to array and GLCD Question
    By pramarn in forum mel PIC BASIC Pro
    Last Post: - 4th October 2006, 04:42
  5. display lcd variable array Ascii
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 22:36
