Counter not counting !!!
Results 1 to 25 of 25
    Sep 2006
    HI, I am not able to make this code work, always leaves me with ORevs = 1 on the LCD.
    I also change the oscillation to 20 Mhz but did not see any difference.
    ken
    ' Internal Oscillation program
    ' LCD
    ' Main loop display the counts and the interrupt routine counts
    '// Define section //
    INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language
    @ DEVICE pic16F88, INTRC_OSC, MCLR_ON
    OSCCON=$60 ' use internal 4MHZ osc
    ANSEL = 0 : ADCON1 = 7
    CCP1CON = 0 'CCP1 module off
    '// LCD configuration //
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    '// PIN configuration //
    TRISA = %11111111 ' Set PORTA.4 (TOCKI) to input for timer0
    TRISB = %00001111 ' Set PORTB
    PortA = 0
    '// Variable Declaration and initialization //
    Revs var word
    ORevs var word
    ANSEL = 0 ' disable A/D so RA4 is digital
    CMCON = 7 ' disable comparators
    OPTION_REG = %00110001 ' RA4 = count input
    ' inc count every 4th falling edge with 1:4 prescale
    ' assigned to TMR0
    Mainloop:
    TMR0 = 0 ' clear count before pause
    PAUSE 20 ' Adjust this to set how long it counts revolutions here
    Revs = TMR0 ' TMR0 counts 1 rev for every 4 pulses
    ORevs = Revs +1
    LCDOUT $FE,1,"ORevs: ",DEC ORevs
    GOTO Mainloop
    As Joe already mentioned earlier, RA4 T0CKI is a Schmitt Trigger input. If your sensor doesn't output a minimum voltage of 0.8 * VDD for logic 1 and 0.2 * VDD or less for logic 0, then the Schmitt Trigger input isn't seeing the correct logic levels, and TMR0 isn't counting your pulses.
    Here's a quick little test program to show how it works when RA4/T0CKI is connected to an I/O-pin to increment the counter.
    @ DEVICE pic16F88, INTRC_OSC, CCPMX_ON, MCLR_OFF
    DEFINE HSER_BAUD 2400
    Loops VAR BYTE
    Revs var BYTE
    TRISA.4=1  ' RA4/T0CKI = input (Timer0 clock input)
    PORTB.5=1  ' USART TX pin idles high
    PORTB.0=1  ' clock output pin to RA4 starts high
    TRISB.0=0  ' clock out pin to RA4/T0CKI = output
    TRISB.5=0  ' USART TX = output
    OPTION_REG = %10110001 ' clk on RA4/T0CKI, falling edge, 1:4 prescale
    Mainloop:
        TMR0 = 0      ' clear count before each pass
        ' output 8 clocks on RB0 to RA4/T0CKI
        FOR Loops = 0 TO 7
          PORTB.0=1   ' RB0 connects to RA4/T0CKI
          PAUSE 5
          PORTB.0=0   ' counter increments on falling edge
          PAUSE 5
        NEXT Loops
        Revs = TMR0   ' get TMR0 count
        IF OPTION_REG.0 THEN
           HSEROUT ["Counts at 1:4 prescale: ",dec Revs,13,10]
           HSEROUT ["Counts at 1:2 prescale: ",dec Revs,13,10]
        OPTION_REG.0 = OPTION_REG.0 ^ 1 ' toggle 1:4 or 1:2 prescale
        GOTO Mainloop
    It works great, but only as long as the input signal meets the threshold levels the Schmitt Trigger input buffer on RA4/T0CKI expects.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Loops VAR BYTE
    Revs var BYTE
    Mainloop:
        FOR Loops = 0 TO 7
          PAUSE 5
          PAUSE 5
        NEXT Loops
        GOTO Mainloop
    I learned something again! I thought Schmitt trigger would switch at 3v, so 80 percent huh? I'm going to write that down. Thanks Bruce !
    Sep 2006
    Hi
    well I am only getting about 3volt, so 0.8 * 5v = 4v, one volt away from triggering. I will a simple amplifier or inverter to the output of my sensor and feed that to the chip
    ken
    Sep 2006
    I think I am getting there but just not quite.
    your program works with the loop for incrementing. I removed the loop , because I have a sensor output, The output is going through an inverter, so now I get either 0 or 5v going into RA4.
    What I now see on the LCD is the incrementation going up high without any look at the input. it goes up to a 1000 in about 3 seconds with the sensor laying there not moving:
    Here is the code I have, mainly Bruce,s code with the addition of the LCD and external oscillation.
    @ DEVICE pic16F88, CCPMX_ON, MCLR_OFF
    DEFINE OSC 20 'use external 20mhz crystal
    Revs var BYTE
    ORevs var word
    Counter var word
    Counter =0
    Mainloop:
    'instead, input from sensor
    Counter = Revs + 1
    LCDOUT $FE,1,"Counter1: ", DEC Counter
    lcdout $FE,$C0, "Counter2: ", DEC Counter
    GOTO Mainloop
    Sep 2006
    also, I used your program andn it seemed to work but I realized that even if I remove the Loop: (or simply remove the connection between RA4 and RB3)
    FOR Loops = 0 TO 7
    PORTB.3=1 ' RB0 connects to RA4/T0CKI
    PAUSE 5
    PORTB.3=0 ' counter increments on falling edge
    PAUSE 5
    NEXT Loops
    the incrementation stays the same change, so I guess there si not effect on TMR0.
    K
    Try this;
    Mainloop:
    PAUSE 5000 ' give it some time to count pulses
    Counter = Counter + 1
    LCDOUT $FE,$C0, "Revs: ", DEC Revs
    GOTO Mainloop
    Counter of course is always going to change every 5 seconds or so, but Revs shouldn't until you have pulses in on RA4.
    Timer0 will automatically count pulses. You don't need to check any regs, bits, etc, just read it & clear it as required.
    -Bruce
    tech at rentron.com
    Sep 2006
    I did output the Revs and it increment without any input:
    not as fast, takes about 2 seconds to get to ten.
    The odd thing is that it increment without changes to RA4.
    I am going to try your code you posted and be back later
    thanks for your time
    Mainloop:
    Counter = Revs + 1
    LCDOUT $FE,1,"Revs: ", DEC Revs
    GOTO Mainloop
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Replies: 42
    Last Post: - 14th January 2008, 12:38
  3. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  4. Replies: 4
    Last Post: - 18th June 2007, 14:38
  5. Microcontroller with 2 way paging application problem
