Hello Guys,
I spent a few days reading the forum, checking and double checking, and I hit a dead end...
I have two PICs 16F88, one master and one slave... I'm able to tell the slave to do something, but I'm not able to read a byte from the slave...
This is the master, pretty simple:
And, this is the slave:Code:'------------------------------------------------------------------------------- '------------------------------------------------------------------------------- ' Master '------------------------------------------------------------------------------- '------------------------------------------------------------------------------- @ device pic16f88, intrc_osc_noclkout ' system clock options @ device pic16f88, wdt_on ' watchdog timer @ device pic16f88, pwrt_on ' power-on timer @ device pic16f88, mclr_off ' master clear options (internal) @ device pic16f88, protect_off ' code protect off '------------------------------------------------------------------------------- DEFINE OSC 8 OSCCON = %01110001 '8mhz '------------------------------------------------------------------------------- CMCON = 7 ADCON1 = 0 ' Disable A/D converter ADCON0 = 0 ANSEL = 0 ' all analog pins to digital '------------------------------------------------------------------------------- DEFINE I2C_HOLD 1 DEFINE I2C_SLOW 1 scl VAR PORTB.4 ' i2c clock input sda VAR PORTB.1 ' i2c data input valor VAR BYTE ' value to read LED VAR PORTA.6 '------------------------------------------------------------------------------- main: valor = 0 ' I2CWrite sda, scl, $01, [31] ' High LED ' Pause 100 ' I2CWrite sda, scl, $01, [30] ' Low LED ' Pause 100 I2CRead sda, scl, $01, [valor] IF (valor = 24) Then High LED Pause 500 Low LED EndIF GoTo main '------------------------------------------------------------------------------- End '-------------------------------------------------------------------------------
Could someone please through some light over here... I really don't know what else to check...Code:'------------------------------------------------------------------------------- '------------------------------------------------------------------------------- ' Slave '------------------------------------------------------------------------------- '------------------------------------------------------------------------------- @ device pic16f88, intrc_osc_noclkout ' system clock options @ device pic16f88, wdt_on ' watchdog timer @ device pic16f88, pwrt_on ' power-on timer @ device pic16f88, mclr_off ' master clear options (internal) @ device pic16f88, protect_off ' code protect off '------------------------------------------------------------------------------- DEFINE OSC 8 OSCCON = %01110001 '8mhz '------------------------------------------------------------------------------- CMCON = 7 ADCON1 = 0 ' Disable A/D converter ADCON0 = 0 ANSEL = 0 ' all analog pins to digital '------------------------------------------------------------------------------- DEFINE I2C_HOLD 1 DEFINE I2C_SLOW 1 '------------------------------------------------------------------------------- SSPIF VAR PIR1.3 ' SSP (I2C) interrupt flag BF VAR SSPSTAT.0 ' SSP (I2C) Buffer Full R_W VAR SSPSTAT.2 ' SSP (I2C) Read/Write D_A VAR SSPSTAT.5 ' SSP (I2C) Data/Address CKP VAR SSPCON.4 ' SSP (I2C) SCK Release Control SSPEN VAR SSPCON.5 ' SSP (I2C) Enable SSPOV VAR SSPCON.6 ' SSP (I2C) Receive Overflow Indicator WCOL VAR SSPCON.7 ' SSP (I2C) Write Collision Detect '------------------------------------------------------------------------------- I2Caddress CON 1 ' Make our address 1 '------------------------------------------------------------------------------- SSPADD = I2Caddress ' Set our address SSPCON = $36 ' Set to I2C slave with 7-bit address '------------------------------------------------------------------------------- LEDR VAR PORTA.3 ' LED 1 LEDL VAR PORTB.3 ' LED 2 BZR VAR PORTA.7 ' Buzzer RL6 VAR PORTB.6 ' Relay 1 RL12 VAR PORTB.5 ' Relay 2 '------------------------------------------------------------------------------- datain VAR BYTE ' Data in dataout VAR BYTE ' Data out '------------------------------------------------------------------------------- GoTo boot '------------------------------------------------------------------------------- i2cslave: ' I2C slave subroutine SSPIF = 0 IF R_W = 1 Then i2crd ' Read data from us IF BF = 0 Then i2cexit ' Nothing in buffer so exit IF D_A = 1 Then i2cwr ' Data for us (not address) IF SSPBUF != I2Caddress Then i2cexit ' Clear the address from the buffer GoTo i2cexit '------------------------------------------------------------------------------- i2cwr: ' I2C write data to us datain = SSPBUF ' Put data into array GoTo i2cexit '------------------------------------------------------------------------------- i2crd: ' I2C read data from us SSPBUF = dataout ' Get data from array CKP = 1 ' Release SCL line GoTo i2cexit ' That's it '------------------------------------------------------------------------------- i2cexit: SSPOV = 0 WCOL = 0 Return '------------------------------------------------------------------------------- boot: Pause 500 High RL12 High RL6 '------------------------------------------------------------------------------- main: dataout = 24 IF SSPIF = 1 Then GoSub i2cslave Toggle LEDL EndIF IF datain = 121 Then ' on 12v High RL12 EndIF IF datain = 120 Then ' off 12v Low RL12 EndIF IF datain = 61 Then ' on 6v High RL6 EndIF IF datain = 60 Then ' off 6v Low RL6 EndIF IF datain = 31 Then ' on buzer High BZR EndIF IF datain = 30 Then ' off buzzer Low BZR EndIF GoTo main '------------------------------------------------------------------------------- End '------------------------------------------------------------------------------- '-------------------------------------------------------------------------------
Thanks a lot!
Daniel.
