Clearing info in an array
Results 1 to 4 of 4
    Dec 2005
    Default Clearing info in an array
    Is there a way to clear data in an array with one instruction? I get tired of spending code space and time on creating a loop to clear the array cells one at a time.
    John P
    How many different array you have?
    Dec 2005
    Question Clearing info in an array
    Currently in my program I am creating the first array of only 8 bytes (x255), but that will expand depending on ease of operation and speed. I'd like to be able to clear the the whole 8 byte array with one command.
    I thought that where the array
    DPA var byte [8]
    was used that I'd be able to clear the whole array by using
    DPA = 0
    but that doesn't work.
    John P
    Virginia Beach, Virginia USA
    Doesn't the CLEAR command (manual section 5.8) work for you?
    That will ZAP everything... otherwise it's a FOR...NEXT loop if you want to be pickky.
    Last Post: - 14th June 2016, 08:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  3. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 00:13
  4. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 05:35
  5. RS232 receive an array (packet)
    Last Post: - 12th February 2008, 06:02
