Somewhere in your program, you are trying to calculate the Modulus (//) of a BIT variable divided by a CONSTANT.ERROR: Macro MOD?TCB not found in macro file.
Darryl,
Thank you!! Thank you!!! Thank you!!!
Only with your help could I find the problem. There was a problem with calculating a modulus 10. My PCs have been running a little jerky lately and there are 2-3 second pauses between editing keystrokes and displaying that stroke on the screen. I must have inadvertently changed
Temp10 // 10
to
Temp10//
It was perfectly good code before doing a massive coding change, so I naturally kept going thru the newly changed code looking for my problem instead of the real error.
Thanks again!!
John P
Darrel,
I apologize for mis-spelling your first name. I was so excited after finding my problem that I used my nephews spelling of the name. Sorry
John P
Virginia Beach, VA. USA
PS I didn't notice the error until I was searching for array information and saw your article on EEProm variables. I will download that article because it may help my other prioblem on clearing a whole array with one command. If not, I'm sure there is plenty to learn. Thanks for that article, too.
John P
No problem John.
That's the way my brother spells it.
EE_Vars can't work with arrays, so I'm not sure how much help it will be for you.
