ADCIN Sampleus time question
Results 1 to 3 of 3
    I guess it depend at least of how neat the signal is, then you add the analog source impedance in the calc. As you have a 10uF cap, which seems to be overkill, you shouldn't have any kind of problem depending what's before the capacitor. Some opamp will begin to oscillate with capacitive load.
    usually 20-50uSec works pretty well with cap ~0.1uF range.
    Nov 2007
    West Covina, CA
    Hi Steve,
    I agree, the 10uF is overkill and mostly experimental. So I get the feeling from what I do understand about the A/D function is that once the sample is made and converted, any more sampleus time is just that, non producing hang time.
    Then all I really need to consider is the calculated time it will take to allow the conversion to complete based on the circuit's impedance and your cool PIC multi calculator and go on with life.
    Thanks for sharing that tool, by the way!
    Louie
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 03:53
  2. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 09:20
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  4. really simple adcin question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 21st April 2006, 10:06
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
