Configuring 16F616
Results 1 to 2 of 2
    Default Configuring 16F616
    First time using a 16F616 and learning there is some different terminology compared to the 16F876A I am used to working with. Can someone confirm this is all correct for listed input and outputs?
    TRISA=%001000
    TRISC=%001111
    INTCON.7 = 0
    Ansel = 0
    A0=No Connection
    A1=Output to LED
    A2=Output to LED
    A3=Pulsin from outside source
    A4/A5= HS OSC
    C0-3=BCD....learned about PortA weak pull-ups after building board
    C4-5=Outputs to control digital pot.
    I have 10k resisitors pulling up C0-3. However C2 is pulled low, either config is still wrong or the board is bad.
    In theory it should work, in practice I may have missed something in the datasheet. Comparator are disabled at POR, PWM is disabled and you have disabled the ADC.. what else?
  1. 16F616 A to D
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 1st May 2009, 16:37
  2. Configuring Defines For 8-bit LCD
    Last Post: - 1st November 2006, 09:59
  3. Configuring register problem
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2005, 20:03
  4. configuring the internal oscillator
    By bartman in forum General
    Last Post: - 30th November 2004, 00:41
  5. need help configuring 16F628
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2004, 18:59
