RECENTLY I TRY TO TRANSMIT MORE THAN ONE STRING LIKE INSTEAD OF "A", I WANT "AB". BUT THE RECEIVER ONLY RECEIVE "A" ONLY, IT CANNOT RECEIVE "AB". IS THAT ANY THING WRONG WITH MY SOURCE CODE.
TRANSMITTER CODE:
' Variable assign
'--------------------------------------------------------------------------H VAR byte
E VAR byte
SYNCH VAR BYTE
JUNK VAR BYTE
'--------------------------------------------------------------------------INPUT PORTB.7
junk = 126
synch = "Z"
H = 65 'STRING "A"
E = 66 'STRING "B"
'--------------------------------------------------------------------------' DATA SEND OUT
'--------------------------------------------------------------------------DATA_TX:
HIGH PORTC.0:PAUSE 50:LOW PORTC.0:PAUSE 50 'LED ON/OFF
CON_TX:
for dat = 1 to 255
serout PORTB.3,N2400,[junk,synch,H,E]
pause 50
next
serout PORTB.3,N2400,[junk,synch,0]
GOTO CON_TX
RECEIVER CODE:
'--------------------------------------------------------------------------' Variable assign
'--------------------------------------------------------------------------RX_DATA VAR BYTE[6]
'--------------------------------------------------------------------------DATA_RX:
HIGH PORTC.2:PAUSE 50:LOW PORTC.2:PAUSE 50 'LED ON/OFF
RX_DATA[14] = 0
CON_RX:
SERIN PORTA.0,N2400,["Z"],RX_DATA
DEBUG "DATA =",STR RX_DATA,10,13
GOTO DATA_RX
IS ANY ONE CAN HELP ME...PLEASE...TQ
