Which conditional expression is faster?
Results 1 to 5 of 5
    Omaha, Nebraska USA
    Default Which conditional expression is faster?
    Which of these is faster to execute?
    IF A+B+C=0 THEN . . .
    or
    IF A=0 AND B=0 AND C=0 THEN . . .
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    This is faster
    IF A+B+C=0
    The generated ASM
    ADD?BBW	_A, _B, T1
    ADD?WBW	T1, _C, T1
    CMPNE?WCL	T1, 000h, L00001
    This
    Generates
    CMPEQ?BCB	_A, 000h, T1
    CMPEQ?BCB	_B, 000h, T2
    LAND?BBW	T1, T2, T2
    CMPEQ?BCB	_C, 000h, T3
    LAND?WBW	T2, T3, T3
    CMPF?WL	T3, L00003
    You will have problem with the first one one day or another (put some values in and figure a roll-over), but the second one is bullet proof.
    If you want to measure it, you may use the regular suggestions
    1. Set a pin before, and clear it after the IF-THEN or code block. Measure the delay with a scope or frequency meter
    2. Same as above, but use an internal Timer and output the data over serail port
    3. Use MPLAB stopwatch
    http://www.picbasic.co.uk/forum/show...33&postcount=9 <-- really handy
    http://www.picbasic.co.uk/forum/show...9&postcount=13
    Wink
    Quote Originally Posted by RussMartin View Post
    or
    Hi, RUSS
    A+B+C = 0 has many solutions AS ... you use an ADDITION and not a Bitwise AND !!!
    253 + 2 + 1 = 0 .... for Bytes !!!
    1 + 1 + 0 = 0 ... for Bits !!!
    so, It can't be equivalent to the second line ... Too Bad !
    Now, let's suppose A, B, C are BITs ...
    so
    IF  A | B | C  THEN Z = 1...
    Will be the fastest ... with PBP.`( 17 asm Lines ...)
    IF  (NOT A & NOT B & NOT C ) THEN Z = 1
    is somewhat longer ...
    BUT, if A,B,C are inputs ... would be faster to mask the other inputs and test if result is 0
    IF ( PORTx & %00000111 ) THEN Z = 1
    Only 12 asm lines ...
    Omaha, Nebraska USA
    Thanks to each and all of you. I appreciate especially the warnings about pitfalls in the summation test; I'll remember those.
    I failed to provide the limits/boundary conditions. I should have qualified the question and put it this way:
    For A, B, C < 2 (and of course not negative!),
    or
    It looks as if Dave assumed the limits I had in mind.
    The reason for my question was that, back in the bad old days, the syntax of conditional statements in FORTRAN IIb (sometimes called "Weather Bureau FORTRAN") was extremely limited, so doing a test like this was easier, if not necessarily faster.
    I happened to try it with PBP in an application, and it worked. I just didn't know how economical it was in terms of generated code. Hence my question.
    Russ
  1. conditional defines in PBP?
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 13th March 2010, 14:40
  2. Replies: 5
    Last Post: - 28th May 2008, 10:20
  3. interrupt handling faster than if's?
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 27th October 2006, 01:25
  4. OT - Firefox browser - faster performance
    By malc-c in forum Off Topic
    Last Post: - 14th August 2006, 10:33
  5. Conditional Compilation
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2006, 20:29
