Noise on PORTC.0 with PIC16F73
Results 1 to 8 of 8
    I have some doubt about it... @POR, Timer1 is already off, CCP as well.
    What you experiment is indeed an RMW issue. You don't want to write to successive output bit by bit, this will cause some problem one day or another, and faster your OSC is, more chance you have to see it happen.
    What you want to do is to write to the WHOLE PORT at once instead of single bits.
    Here:
    PORTC=7
    PORTC=0
    Goto Here
    Use shadow register, modify it, then dump it to your specific PORT, that's my suggestion.
    Question
    Hi, Passion
    What Kind of load do you have on portC.0 ???
    Here, your signal might not be far from ... ~ 700 kHz ( at first sight ! 555 Khz ... at second sight )
    Here:
    PORTC=7
    PORTC=0
    Goto Here
    PortC value on POR,BOR xxxx xxxx
    value on all other resets uuuu uuuu
    PortC Data direction Register
    value on all resets 1111 1111
    My theroy is T1 osc was causing his noise.
  1. Pretty Sure a Noise Problem
    By Tobias in forum General
    Last Post: - 10th December 2009, 01:46
  2. Loud Noise at 20khz
    By koossa in forum Off Topic
    Last Post: - 14th July 2009, 10:24
  3. Need suggestions for noise suppression
    By paul.barsamian in forum General
    Last Post: - 29th March 2008, 15:37
  4. Getting rid of noise of car battery/alternator
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 06:11
  5. (Off Topic) Noise from battery supply
    By CLARE in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2004, 11:01
