pic16f88 & voltage
Results 1 to 11 of 11
    Oct 2008
    Default pic16f88 & voltage
    i have a pic16f88 & xbee on the same breadboard. the pic should run at in input V between 2.0v to 5.5v.
    on the breadboard i have a 7805 for the 5v to the pic and a LD3.3 regulator for the xbee.
    however, having two voltage regulators is causing a problem when the xbee gnd is on the same rail as the 5v. that issue is probably evident to an EE, which I am not.
    Yet, I can't get the pic16f88 to function with 3.3v. At this point I was hoping to have only one voltage regulator and be able to power the pic & xbee.
    is there a programmatic setting i'm not using or should be using to get this pic to run with 3.3v ?
    What OSC are you running the PIC at?
    Look at the electrical specifications in the PICs data sheet to see what speeds work with different voltages.
    Which inputs do you use for Xbee ???
    It looks like the 16F88 needs a minimum of 4V to operate. The 16LF88 needs only 2V. Try the LF part, use 3.3V for both and turn off Brownout Detect.
    Oct 2008
    mackrackit
    for this project, i have "DEFINE OSC 8"
    i've missed something there, thx for the reminder
    Acetronics
    pin 1 for 3.3Vcc
    pin 3 for input from RB5(tx) from pic
    peterdeco1,
    actually i didn't see that in the datasheet i have but i'll look again. in the meantime i'll pick up some 16LF88's which are better suited to this particular prototype session.
    thx
    Red face Bad way of asking the Question ... ( I think )
    pin 1 for 3.3Vcc
    I think I didn't write it correctly ...
    Which inputs of the PIC do you use for Xbee reading ...
    Oct 2008
    no problem, i read backwards randomly at times, so maybe i mis-read the question.
    i use pin RB2(rx) is the only reading from the xbee currently.
    Oct 2008
    Quote Originally Posted by peterdeco1 View Post
    via the data sheet for the PIC16LF88-I/P on mouser's site i do now, see the pic16f88 listed at 4V.
    thanks
  1. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 21:32
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 20:20
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  4. Replies: 8
    Last Post: - 7th December 2006, 16:42
  5. Project-Read voltage in / different voltage out
    By andydoc in forum mel PIC BASIC
    Last Post: - 8th August 2005, 16:20
