serin and serin2
Results 1 to 5 of 5
    rastan's Avatar
    rastan Guest
    Question serin and serin2
    ive just managed to sucessfully use the sein command but i noticed that the pbp manual specifically said that only one character can be used. does this mean that to send a string of information i would have to send letter after letter or is there some sort of modifier that i dont know about.
    if this is the case would it be easier to use the serin2 command?
    thanks
    Talking
    you talk about two different things here! BTW...
    Yes you can receive only one character at a time... every character is a byte, one variable then. So in this case you have to place every character in a array or EEPROM (As you wish).
    BUT
    you can send almost everything. A string will be send in one shot when using SEROUT statement.
    rastan's Avatar
    rastan Guest
    ok how would i go about puttin the information into the array. theres nothing about it in the manual.
    cheers.
    phil
    well the easiest solution is to do a simple loop and waiting of an EOT, CR,LF or else to finish storing into ARRAY. i'll assume a 8 element array here.
    SerialDataIn VAR BYTE
    MyArray VAR BYTE[8]
    Looping VAR BYTE
    CR con 13
    Looping = 0
    start:
    while (Looping<8) and (SerialDataIn != CR)
         serin serpin,baudrate,SerialDataIn
         if SerialDataIn != CR then
              MyArray[Looping] = SerialDataIn
              Looping = Looping +1
    wend
    Phil, If you use the SERIN2 command you can load an entire array with a single line of code. Here is a line that would work for you:
    MyArray VAR BYTE[8]
    CR con 13
    start:
    SERIN2 serpin,baudrate,[STR MyArray\8\CR]
    This line of code will fill the array with no more than 8 received characters or as many characters until it reaches a cariage return.
    It's all in the manual......
    HTH,
  1. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 03:56
  2. Serin vs Serin2
    By The Master in forum mel PIC BASIC
    Last Post: - 19th October 2007, 16:50
  3. serin and serin2??? need to understand
    By tkly36 in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 05:13
  4. Serin / Serin2 / Debugin Differences
    Last Post: - 19th January 2006, 06:32
  5. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 18:59
