I'm trying to learn to use the Capacitive Sensing Module (CSM) on the PIC16F727. I've had some minor success getting the CSM set up and running, and with reading the count from TMR1 to an LCD module.
I'm using (trying) Darrel's Instant Interrupts to run an ISR when TMR2 matches PR2, but I clearly don't understand what I'm doing yet...
Here's the part that works so far:
I've got the CSM oscillator running and I can see the triangle wave on pin B0. I've got a wire and "touchpad" connected to it, and when I touch the pad the oscillator slows way down, so that part is working great.
Here's what I'm *trying* to do at this point :
Timer1 is used to count pulses on the cap sensing oscillator. It is set up so that Timer2 controls the gate of Timer1 and starts/stops the Timer1 counter.
Timer2 counts until it matches the value in the PR2 register, then stops Timer1 and triggers an interrupt.
The ISR reads the count in the Timer1 register and stores it in a variable called "timercount", then it resets the registers to 0, resets Timer2 to 0, clears the Timer2 interrupt flag, and restarts the timers.
The main loop is supposed to read the contents of "timercount" and display it on an LCD so I can read the change in timercount when a finger touches the sensing pad.
Here's the problems I'm having (so far):
First, the Interrupt seems to "steal the show" and the program never enters the main loop and displays the data on LCD, UNLESS I put a "goto Main" inside the ISR routine. Then it will display my value on the LCD.
Second, the count in TMR1 seems to be entirely dependent on the length of the "pause" in the main loop. With 100mS pause the timer reads about 15,000 counts, with a 200mS pause it reads about 29,000 counts. What's up with that? The ISR zeros the timers each time through.
I've read sections 11-14 (using the timers and CSM) of the 16F727 datasheet (41341B.pdf) *repeatedly*, as well as AN1103 and AN1171 which explain using the CSM in the 16F727. Hey, I even managed to make Darrels "Blinky light" interrupt example work for me, but alas, I seem unable to pull it all together and make the touch sensor routine work. I figured I'd start by reading the count in TMR1 to an LCD so I can see what's happening..
I've been hammering away at this for quite a while and starting to feel rather lost.
Here's the code I've got so far if someone would *please* be so kind as to take a look and offer advice..
Code:'------------------------------------------------------------------------------- 'Trying to learn to use the Capacitive Sensing Module on a 16F727 -------------- '------------------------------------------------------------------------------- @ __config _CONFIG1, _DEBUG_OFF & _PLL_EN & _BORV_2_5 & _BOR_ON & _CP_OFF & _MCLRE_OFF & _PWRT_EN & _WDT_OFF & _INTOSCIO @ __config _CONFIG2, _VCAP_RA0 Include "MODEDEFS.BAS" ' Include Shiftin/out modes INCLUDE "DT_INTS-14.bas" ' Base Interrupt System INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts DEFINE LCD_DREG PORTA ' Set LCD Data port DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus DEFINE LCD_RSREG PORTA ' Set LCD Register Select port DEFINE LCD_RSBIT 2 ' Set LCD Register Select bit DEFINE LCD_EREG PORTC ' Set LCD Enable port DEFINE LCD_EBIT 0 ' Set LCD Enable bit DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) DEFINE ADC_BITS 8 ' Set number of bits in ADC result DEFINE ADC_CLOCK 3 ' Set clock source for ADC (rc = 3) DEFINE ADC_SAMPLEUS 100 ' Set ADC sampling time in microseconds DEFINE OSC 4 OSCCON = $10 'set oscillator to 4 Mhz TRISA= %00000000 'Set 'em all to outputs ANSELA= %00000000 'Set 'em all to digital TRISB= %11111111 'all input ANSELB= %11111111 'all analog TRISC= %00000000 'Set portC all outputs CPSCON0 = %10001101 'Cap sense on, high range oscillator CPSCON1 = %00000000 'Cap sense channel input 0 is selected '-----Alias Pins RW var PORTC.3 'Read/Write line for the LCD '-----Allocate Variables timercount var word ' A place to store the count from TMR1 '-----Set up Interrrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR2_INT, _CheckCount, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE TMR2_INT ; enable Timer 2 interrupts low rw 'LCD Read/Write line low (write) Pause 200 'Let the LCd wake up lcdout $fe, 1 'Clear LCD '----- Timer Setup T2CON.2 = 1 'TMR2 on T2CON.0 =1 'adjust prescaler PR2 = $B4 ' w/prescale=1:1, $B4 sets 125us scan rate. '= 10110100 PIR1.1 = 0 'Clear the TMR2 interupt flag PIE1.1 = 1 'Turn TMR2 interrupt enable on T1CON = %11010101 'clock=CAPOSC, prescale=1:2, dedicated OSC disabled, no external clock synchronize, timer on T1GCON = %11100010 'Timer1 gate init/ Toggle Mode PIR1.7 = 0 'Clear Gate Interrupt Flag PIR1.1 = 0 'clear the TMR2 interupt flag PIE1.7 = 1 'Enable Gate Interrupt Goto main 'Just get it going... '---[TMR2 - interrupt handler]-------------------------------------------------- disable 'I think I need to kill the interupts here..? CheckCount: T2CON.2 = 0 'stop timer2 T1CON.0 = 0 'stop timer1 timercount = TMR1L + TMR1H << 8 'stuff the contents of the timer register into a word TMR1L = 0 'reset counter to 0... TMR1H = 0 'upper 1/2 too TMR2 = 0 'rest timer 2 PIR1.1 = 0 'Clear TMR2 Interrupt Flag T1CON.0 = 1 'restart timer1 T2CON.2 = 1 'restart timer2 ' gosub main 'if I don't add this, I never seem to get out of the interrupt and return to the main routine... @ INT_RETURN enable 're-enable interrupts '----Main loop----------------------------------------------------------- Main: LCDOUT $fe,2, " Count= ", dec timercount," ",$fe,$C0," TMR2 = ", dec timertemp," " pause 100 'changing the duration of the pause also changes the count on timer1. Why? return GOTO Main end
Thanks very much,
