I'm having problems with reading a AT24C1024 EEPROM
Results 1 to 2 of 2
    Default I'm having problems with reading a AT24C1024 EEPROM
    You guys can help me hello
    I'm having problems with reading a AT24C1024 EEPROM,
    I'm able to read a line of information, would like to know how to perform the reading of the other lines because the messages are displayed on the LCD with characters on black
    Here is the code
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    TRISB = 0
    CMCON = 7
    SCL var PORTA.0 ' Clock pin
    SDA var PORTA.1 ' Data pin
    E0 var byte
    B1 var byte ' Data 1
    B2 VAR BYTE
    b1 = e0 + $00 'B1 is dados da EEPROM 'not sure what you are using E0 + $20 for?
    B1 = E0 + $10
    ADDR var WORD ' 24c32a uses 2 bytes for address ( 12 bits, high 4 bits are 0's )
    ADDR = 0 ' where in eeprom to store first byte, I chose 0 (start of eeprom)
    I2CWRITE SDA,SCL,$A0,ADDR,[16,"pic basic pro "] ' "pic basic pro" is 16 characters long
    I2CWRITE SDA,SCL,$A1,ADDR,[16,"Mechatronics "]
    LCDOUT $FE,1 'clear &home lcd screen (change this to position on screen you want your data)
    ADDR = 0
    WHILE ADDR < 16 'Character Loop to read the 16 bytes "pic basic pro"
    I2CREAD SDA,SCL,$A0,ADDR,[b1] 'read byte from eeprom
    lcdout b1 'display byte on lcd
    ADDR = ADDR + 1 'advance address to next eeprom location
    I2CREAD SDA,SCL,$A0,ADDR,[b2]
    wend 'done with all of string
    lcdout $FE, $0C
    Default Re: I'm having problems with reading a AT24C1024 EEPROM
    You really need to read the manual page 158 on I2CWRITE as the way you are using it is all wrong. You can not expect to write a string to a page like you are doing. Also you are writing the second string to another AT24C1024 from the looks of it. Is this correct?
    EN82fn
  1. Problem reading 93c46 EEprom
    By dj.lambert in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 06:10
  2. Reading eeprom
    By Lotondo in forum Off Topic
    Last Post: - 21st February 2007, 17:37
  3. Reading EEPROM data?
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 10th March 2006, 17:06
  4. problem of reading eeprom 24lc515
    By mike12 in forum mel PIC BASIC Pro
    Last Post: - 1st January 2006, 17:36
  5. 93c46 Eeprom Writing/reading Help
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 13th June 2005, 20:40
