18f452 portc.1
Results 1 to 11 of 11
Thread: 18f452 portc.1
    Ohio
    Default 18f452 portc.1
    Hi All,
    I need to use PORTC.1 as a digital I/O pin on a 18F452 pic. I have looked at the documentation for this microprocessor but I could not find how to configure this pin as just a digital I/O. When I run the code PORTC.1 = 1, the output remains at zero voltage. If run the code HIGH PORTC.1 it will output 5 volts. All other pins on this port work fine except for PORTC.1. I know this pin has special functionality that is causing this problem I think. Does anyone know how to configure this pin for a digital I/O?
    Mark
    Lightbulb nothing strange ...
    Hi, Mark
    So, everything fine !!!
    PORTC is an 8-bit wide, bi-directional port. The corresponding
    Data Direction register is TRISC. Setting a
    TRISC bit (= 1) will make the corresponding PORTC
    pin an input (i.e., put the corresponding output driver in
    a Hi-Impedance mode). Clearing a TRISC bit (= 0) will
    make the corresponding PORTC pin an output (i.e., put
    the contents of the output latch on the selected pin).
    IF you had Read This F... Datasheet ...
    Ohio
    Hi Alain,
    I've tried TRISC = %00000000 setting all to ouputs before. I get the same result.
    Mark
    Feb 2009
    Default adcon
    You need to set the adcon register. Search for it in the datasheet. If I get time later I'll download it and look.
    Nemesis
    Hi Mark
    What's the load on PortC.1 ??? ... mosfet Gate ???
    PS: no other "disturbing" function on this PIN ... except
    When the Timer1 oscillator is enabled (T1OSCEN is
    set), the RC1/T1OSI and RC0/T1OSO/T1CKI pins
    become inputs. That is, the TRISC<1:0> value is
    ignored, and the pins are read as ‘0’.
    What about T1OSCEN ??.
    Aug 2008
    Pls post your code here so that we can see what's wrong.
    Ohio
    When running the code below I do NOT get 5 volts out of PORTC.1. I can change the code to use any other pin on PORTC and I DO get 5 volts out. The problem is with just PORTC.1
    Mark
    Input PORTC.2
    output PORTC.1
    INPUT PORTC.0
    output PORTD.0
    OUTPUT PORTC.3
    OUTPUT PORTD.1
    ADCON1 = 7 'set I/O pins to digital on PORT.A
    define OSC 20
    define LOADER_USED 1 ' bootloader
    Include "modedefs.bas"
    T1CON = 3 'Turns on Timer1
    PORTC.1 = 1
    Feb 2009
    Default shutdown ad for now
    turn off ad all together. adcon0 = 0
    see if that helps.
    Nemesis
    Wink
    THE Good Ol' Method ... always lead to success !!!
    '@  __CONFIG    _CONFIG1L, _WDT_OFF_1L & _WDTPS_128_1L
    @   __CONFIG    _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    @	__CONFIG	_CONFIG2L, _BOR_OFF_2L & _BORV_27_2L & _PWRT_ON_2L
    @   __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    '@  __CONFIG    _CONFIG3L, _WDT_OFF_3L & _WDTPS_128_3L
    @   __CONFIG    _CONFIG3H, _CCP2MX_OFF_3H
    @   __CONFIG    _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    '@  __CONFIG    _CONFIG4H, _WDT_ON_4H & _WDTPS_128_4H
    @   __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @   __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @   __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    @   __CONFIG    _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @   __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @   __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
    Input PORTC.2
    output PORTC.1
    INPUT PORTC.0
    output PORTD.0
    OUTPUT PORTC.3
    OUTPUT PORTD.1
    define OSC 8                                                        ' to suit my Easy Pic5
    'define LOADER_USED 1 ' bootloader                          '        "
    More:
    PORTC.1 = 1
    HIGH PORTC.1
    PAUSE 500
    PORTC.1 = 0
    LOW PORTC.1
    PAUSE 500
    GOTO More
    It's in, the CONFIG !!! ...
  1. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 00:21
  2. Pic 16 F877 to 18F452...?
    Last Post: - 31st October 2007, 16:54
  3. 18F452 compile problem
    By pcbb in forum General
    Last Post: - 21st April 2007, 03:16
  4. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 04:56
  5. Replies: 5
    Last Post: - 17th February 2006, 00:43
