Little ADC Help PLease !!!
Results 1 to 2 of 2
Threaded View
  1. #2
    Aug 2005
    Here is a bit of code I am using at the moment that seems to work well.
    Wait for 255 to be sent from PC then samples and sends reply back.
    'Define ADCIN parameters
    ' Set number of bits in result
    DEFINE ADC_BITS 10
    ' Set clock source (3=rc)
    DEFINE ADC_CLOCK 3
    ' Set sampling time in microseconds
    DEFINE ADC_SAMPLEUS 10
    ' Set PORTA to all input
    TRISA = %11111111
    ' Set up ADCON1 to tell it to right justify and enable A/D channel 0
    ADCON1 = %10000010
    ' Maximum buffer size
    USBBufferSizeMax con 8
    ' Input buffer size
    USBBufferSizeTX con 8
    ' Output buffer size
    USBBufferSizeRX con 8
    ' The USB buffer variables...
    USBBuffer Var ByteUSBBufferSizeMax
    USBBufferCount Var Byte
    ' Other variables
    datawait var byte
    ' Create variable to store result
    adcVar VAR WORD
    'Wait Half a second let ADC settle
    ' Initialise USB...
    usbinit
    ***' * Start of Main Routine ** **
    usbstart:
    'Clear main wait variable
    datawait=0
    'Go check for a USB packet
    gosub DoUSBIn
    ' Check data Received in and load variables
    datawait=usbbuffer(0)
    'Check if PC wants ADC sent back
    if datawait=255 then
    'Gosub main ADC routine
    gosub main
    'Go back to the start and wait for the next command
    goto usbstart
    *' * Main Sample Routine **
    ' Read channel 0
    ADCIN 0, adcVar
    ' Wait.01 second
    Pause 10
    'Shift the result down to 10 bits
    ADcvar = adcvar >> 6
    'Set the Result
    usbbuffer(0)=adcvar.highbyte
    usbbuffer(1)=adcvar.Lowbyte
    'Send it out to PC
    gosub dousbout
    *' * Receive data from the USB bus **
    DoUSBIn:
    ' RX buffer size
    USBBufferCount = USBBufferSizeRX
    ' Keep connection alive
    USBService
    ' Read data, if available
    USBIn 1, USBBuffer, USBBufferCount, DoUSBIn
    *' * Send Data out **
    DoUSBOut:
    ' TX buffer size
    USBBufferCount = USBBufferSizeTX
    USBService
    ' If bus available, transmit data
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut
    Cheers
    Sean.
    http://www.cncdudez.co.uk
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. 10 bit ADC display on LCD using 16f873
    By pr2don in forum mel PIC BASIC
    Last Post: - 6th March 2010, 19:29
  3. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 16:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
