16-Channel LED Drivers
Results 1 to 12 of 12
Threaded View
  1. #11
    Apr 2005
    Virginia
    Sponge_Bob,
    Tsk, tsk - you're lucky I'm in a generous mode tonight. Alright, first thing to do is open the PBP INC file for the 16F628A and comment out the config line. Assuming you're using Windows and have everything installed in the default locations go to: C:\pbp and open the file named 16F628A.INC. Place a semicolon in front of the line starting with: __config and save the file.
    I've included a schematic to try out. And here's some code to try:
    INCLUDE "modedefs.bas"
    asm
            __config _INTOSC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF & _BOREN_OFF & _PWRTE_ON
    endasm
    DEFINE OSC 4								' Tell the program the oscillator is running at 4 MHz
    CMCON.0 = 1									' Turn off comparators
    CMCON.1 = 1									' Turn off comparators
    CMCON.2 = 1									' Turn off comparators
    VRCON.6 = 0									' Disconnect Vref from RA2
    VRCON.7 = 0									' Vref is powered off
    TRISA = %11111111							' Make all port a pins inputs
    TRISB = %11101000							' Make port b pins 0-2 & 4 outputs and the rest as inputs
    PORTA = $00									' Set all port a pins to low
    PORTB = $00									' Set all port b pins to low
    SPI			VAR		PORTB.2					' Serial input to STP16DP05
    CLK			VAR		PORTB.1					' Clock input to STP16DP05
    LE			VAR		PORTB.0					' Enable pin for STP16DP05
    OE			VAR		PORTB.4					' PWM / ON & OFF for LEDs
    LED_value	VAR		word					' Variable used to send data to STP16DP05
    flip		VAR		bit						' Used to determine which direction to scroll LEDs
    LOW OE										' Turn on LEDs
    LED_value = $FFFF							' Set LED value equal to $FFFF to turn on all the LEDs
    Test:										' Test Routine - Flash all LEDs once
    	SHIFTOUT SDI, CLK, 1, [LED_value\16]	' Send data to STP16DP05
    	HIGH LE									' Enable the STP16DP05
    	LOW LE									' Disable the STP16DP05
    	PAUSE 500								' Wait for half a second
    	LED_value = $0000						' Set LED value equal to zero to turn off all the LEDs
    ' To do the same thing without sending data to STP16DP05 multiple times, try this:
    	HIGH OE									' Turn off all LEDs regards of state of latches on STP16DP05
    	LOW OE									' Turn on all LEDs where latches are enabled
    	LED_Value = $0001						' Set LED value to %0000000000000001 to turn on first LED
    Main:										' Main Routine - Simple Knight Rider Effect
    	IF LED_value = $8000 THEN flip = 1		' If LED value is equal to %1000000000000000, then set flip equal to one
    	IF LED_value = $0001 THEN flip = 0		' If LED value is equal to %0000000000000001, then set flip equal to zero
    	IF flip = 0 THEN						' If flip is equal to zero, then
    		LED_value = LED_value << 1			' Shift LED value to left by one
    	ELSE									' If flip is not equal to zero, then
    		LED_value >> 1						' Shift LED value to left by one
    	ENDIF									' End if statement
    GOTO Main									' Go to Main routine
    END											' End program should it run awry
    Now, please note that I haven't tried this code out, but hopefully it's enough to get you started. Let me know if you have any problems and good luck!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. DMX512 and PWM LED Drivers
    By Bronx68 in forum mel PIC BASIC Pro
    Last Post: - 8th September 2007, 05:53
  5. LCD will not start
