Vdip1
Results 1 to 18 of 18
Thread: Vdip1
    Quote Originally Posted by sky071022 View Post
    Any PIC that you would recommend to us?
    We were planning to use PIC16F688 or PIC16F560. Would that be a good choice?
    I think the main thing to consider (in your case) when picking a PIC is to find one that has enough code space ram and I/Os for the application. The smallest PIC I have used with the VDIP1 is a 16F88. As the project progressed I found that I was scrambling for pins. But that happens with a lot of projects.
    RTS of VDIP1 is to be connected to which pin of PIC? Any pin of the port?
    RTS can be connected to most any pin, just consider ADC and comparators may be on the same pin and need to be shut off.
    Feb 2009
    Should I include in the program to make PIC to send data to VDIP1 only when RTS is low? Does RTS function in such way?
    For the programming part, does it work by just simply sending command through TXD to VDIP1? Any delays to be considered?
    Can I have an example of PIC code to make VDIP1 perform data backup of flash drives to another flash drive? We have added an external USB port for VDIP1, but we are just having problems with the programming. We've tried many codes that we wrote ourselves but most fails..
    The link given up in post#3 tells all about writing data to the VDIP1.
    Do you mean for upgrading the VDIP1 firmware? Like I said before, the easy way is to have the new firmware on a flash drive. When the VDIP1 starts the firmware will be updated.
    Nope, I do not have such code.
    If you post your code we might be able to help you figure out what is wrong.
    Feb 2009
    Default 6 days left
    Do we have to send just the command "210D" to VDIP1 to make it fetch data automatically from host Flash drive to slave Flash drive?
    6 days left...
    for what?
    Feb 2009
    Default 5 days....
    Going to pass up product. any1 can help???
    Feb 2009
    Actually we are suppose to come out with a product for this course we take, known as "System Design".
    We are trying to design a device to perform USB memory backup device. From one USB mass storage to another.
    Few posts above are posted by my friends.
    We are still having problems with the programming part now.
  1. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 20th August 2013, 13:51
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 12:34
  3. PIC interfacing with FTDI's VDIP1
    By Vidya in forum mel PIC BASIC Pro
    Last Post: - 12th May 2008, 17:02
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 22:40
  5. Replies: 4
    Last Post: - 3rd January 2008, 23:41
