Vdip1
Results 1 to 18 of 18
Thread: Vdip1
    Feb 2009
    Default Vdip1
    Need help to do reflashing of the VDIP1 module. We tried using flash disk to do so but seems that it has failed. We connected the 5V and GND pins to the signals required. But when we plug in the flash disk, nothing seems to happen. We were wondering, do we need any extra hardware configuration for reflashing VDIP1 module?
    May be ( ? ) some interesting links here :
    http://www.elektor.fr/magazines/2008...b.712338.lynkx
    You need to ground one pin before power up.
    For more information see this:
    http://www.picbasic.co.uk/forum/showthread.php?t=7700
    Nick
    If you have all of the power pins connected and pin 10 (CTS) connected to ground the LEDs should blink when ever a memory stick is plugged in.
    If the stick has a file named
    FTRFB.FTD
    in the root directory, the VDIP module will start the flash process from there.
    Feb 2009
    VDIP1 is really driving me crazy. Thanks for all the help. Hope it works.
    Feb 2009
    By the way, do we have to do something to the jumper setting for reflashing the VDIP1? Which mode of jumper should we use?
  1. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 20th August 2013, 14:51
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. PIC interfacing with FTDI's VDIP1
    By Vidya in forum mel PIC BASIC Pro
    Last Post: - 12th May 2008, 18:02
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. Replies: 4
    Last Post: - 4th January 2008, 00:41
