Vdip1
Results 1 to 18 of 18
Thread: Vdip1
    Feb 2009
    Default Vdip1
    Need help to do reflashing of the VDIP1 module. We tried using flash disk to do so but seems that it has failed. We connected the 5V and GND pins to the signals required. But when we plug in the flash disk, nothing seems to happen. We were wondering, do we need any extra hardware configuration for reflashing VDIP1 module?
    May be ( ? ) some interesting links here :
    http://www.elektor.fr/magazines/2008...b.712338.lynkx
    You need to ground one pin before power up.
    For more information see this:
    http://www.picbasic.co.uk/forum/showthread.php?t=7700
    Nick
    If you have all of the power pins connected and pin 10 (CTS) connected to ground the LEDs should blink when ever a memory stick is plugged in.
    If the stick has a file named
    FTRFB.FTD
    in the root directory, the VDIP module will start the flash process from there.
    Feb 2009
    VDIP1 is really driving me crazy. Thanks for all the help. Hope it works.
    Feb 2009
    By the way, do we have to do something to the jumper setting for reflashing the VDIP1? Which mode of jumper should we use?
    Feb 2009
    How do we know that the Firmware has been loaded in successfully? The 2 LED's of VDIP1 flashes alternately on powering ON. When flash disk is plugged in, 1st LED ON and 2nd LED OFF for under 1 sec. After that, the state of the 2 LED's change and lastly, the LED state became stable (only LED1 is ON). Does this mean the FW has been loaded in (VDIP1 reflashed)?? The process happened in just few seconds, is this ok?
    Quote Originally Posted by sky071022 View Post
    If you are using serial mode then the two sets of jumpers with three pins should be jumped across 1 and 2 or 2 and 3. It does not matter as long as both are the same.
    The easy way I think is to connect pin 6 through a level shifter (max232) and monitor the VDIP on a terminal. It does not take long to update/change the firmware, small file.
    For that matter , use a terminal to learn how the VDIP works, practice sending commands and reading the feed back.
    Feb 2009
    Question
    We are trying to design a product to transfer data using FIFO mode. The problem now is it doesn't show any respond like when we connect it using UART mode. The LED's just ON alternately for 2 seconds only indicating power on. But, when a flash disk is plugged in, nothing happens. What seems to be the problem?
    Should ground all the address lines? Any other hardware config?
    By the way, can MCU 8051 be used as a monitor for VDIP1? Is it compatible with VDIP1? Or maybe any other suggestion for the monitor?
    Thanks.
    I have never used FIFO mode...
    In UART mode I have the jumper as stated above, the two grounds going to ground, 5 Volt pin connected, CTS(pin 10) to ground, RTS(pin 9) to the PIC for flow control, TXD(pin 6) and RXD (pin 8) going to the PIC for data transfer. all other pins are floating.
    MCU 8051is not a serial level converter. To connect the VDIP to a PC you will to invert the signal... MAX232 or similar.
    Feb 2009
    Any PIC that you would recommend to us?
    We were planning to use PIC16F688 or PIC16F560. Would that be a good choice?
    RTS of VDIP1 is to be connected to which pin of PIC? Any pin of the port?
    I think the main thing to consider (in your case) when picking a PIC is to find one that has enough code space ram and I/Os for the application. The smallest PIC I have used with the VDIP1 is a 16F88. As the project progressed I found that I was scrambling for pins. But that happens with a lot of projects.
    RTS can be connected to most any pin, just consider ADC and comparators may be on the same pin and need to be shut off.
    Feb 2009
    Should I include in the program to make PIC to send data to VDIP1 only when RTS is low? Does RTS function in such way?
    For the programming part, does it work by just simply sending command through TXD to VDIP1? Any delays to be considered?
    Can I have an example of PIC code to make VDIP1 perform data backup of flash drives to another flash drive? We have added an external USB port for VDIP1, but we are just having problems with the programming. We've tried many codes that we wrote ourselves but most fails..
    The link given up in post#3 tells all about writing data to the VDIP1.
    Do you mean for upgrading the VDIP1 firmware? Like I said before, the easy way is to have the new firmware on a flash drive. When the VDIP1 starts the firmware will be updated.
    Nope, I do not have such code.
    If you post your code we might be able to help you figure out what is wrong.
    Feb 2009
    Default 6 days left
    Do we have to send just the command "210D" to VDIP1 to make it fetch data automatically from host Flash drive to slave Flash drive?
    6 days left...
    for what?
    Feb 2009
    Default 5 days....
    Going to pass up product. any1 can help???
    Feb 2009
    Actually we are suppose to come out with a product for this course we take, known as "System Design".
    We are trying to design a device to perform USB memory backup device. From one USB mass storage to another.
    Few posts above are posted by my friends.
    We are still having problems with the programming part now.
  1. VDIP1 (Vinculum - FTDI) problems
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 20th August 2013, 14:51
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. PIC interfacing with FTDI's VDIP1
    By Vidya in forum mel PIC BASIC Pro
    Last Post: - 12th May 2008, 18:02
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. Replies: 4
    Last Post: - 4th January 2008, 00:41
