Minimizing code....
Results 1 to 7 of 7
    Maybe I am missing something...
    'Write to the Display
    GOSUB LCD_THINGY
    'Do Whatever
    'Write to the Display again
    GOSUB LCD_THINGY
    'Do Whatever again.....
    LCD_THINGY:
    gosub LCD_HOME 'clear the LCD and set the cursor to 00
    For y=0 To 64
    Gosub modescreen1b 'software version
    OUT_BITS = ascii
    gosub ioxwriteb
    Pause 1
    gosub LCD_DATA_EN 'send the "Software Version" message
    Next y
    initscreenb:
    Lookup y,["Software Ver: DL1.00A "],ascii
    Is something like that what you had in mind?
    Feb 2009
    Default similar to this psuedocode....
    ' print message a
    GOSUB LCD_THINGY(messagea)
    ' print message a
    GOSUB LCD_THINGY(messageb)
    etc...
    messagea:
    Lookup y,["Message A"],ascii
    messageb:
    Lookup y,["Message B"],ascii
    Can you pass an argument to a sub like in Visual Basic?
    No, but this might work for you..
    ' print message a
    GOSUB messagea
    ' print messageb
    GOSUB messageb
    etc...
    messagea:
    GOSUB LCD_THINGY
    messageb:
    GOSUB LCD_THINGY
    Feb 2009
    Hi Dave,
    Thanks again for your help.
    I have considered your idea but I can't figure out how to implement it because the GOSUB LCD_THINGY routine makes 64 lookups of the table in question.
    TR
    Might be a good time to post your code as it is right now, I am sure there is something I am missing.
    From the manual :
    An unlimited number of subroutines may be used in a program. Subroutines may also be nested. In other words, it is possible for a subroutine to call another subroutine. Such subroutine nesting should be restricted to no more than four levels deep (12 levels for 17Cxxx and 27 levels for 18Cxxx)
    So as long as the look up table block does not call a sub of a sub then you shoulde OK with 64 GOSUBS to the lookup block and back.
    Bombay, India
    Hi Terd
    This is how I do it when I have a number of messages to either print or put out to a 7 segment display.
    ' Thank DT for this Macro
    GetAddress macro Label, Wout       ; Returns the Address of a Label as a Word
        CHK?RP Wout
        movlw low Label
        movwf Wout
        movlw High Label
        movwf Wout + 1
    Address         var     word
    gr[0]             var     byte
    ' Examples of how to put your strings in memory
    prn_SetDate:       PokeCode "Date changed",0
    prn_SetTime:       PokeCode "Time changed",0
    prn_LogPrinted:    PokeCode "Log printed",0
    ' And this is how to use it
      @ GetAddress _prn_SetDate, _Address
      gosub Prt_puts   ' This is my routine to put the string to Printer.
                             ' You could change this to your LCDout routine.
    ' And this is My Prt_puts function
    ' Print an ASCIIZ string
    ' Input - Address points to the string
    Prt_puts:
      repeat
        peekcode Address, gr[0]             ' read a byte to GR[0] (general register 0)
        if gr[0] then                             ' if end of message (0) not found,
          gosub Prt_putc                       ' print this character
          Address = Address+1               ' advance to the next position of input string
      until gr[0]=0                              ' go back if the message end is found
    This is not adapted to your requirement, but, I think you can do that yourself.
  1. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
