decrypted data
Results 1 to 6 of 6
Thread: decrypted data
    Jul 2007
    paris
    Default eeprom
    Hello
    I think it's complicated, but you must know.
    And you how you could have done to protect data of a eeprom 24lc512
    Or perhaps the program that sends false with true and blurs the text.
    thank you for your help
    Jul 2007
    paris
    Default Decrypte
    helo
    Apparently in order to decode it must test all the values from 0 to 255 and
    My case I'm only 10 digits? 0 to 9. As is always numeric characters
    over a length of 40 characters, there will be several repetitions of figure?
    If coding for each digit is a different value to not be able to compare
    compared to its own value and its relative position in the text encrypt
    so it will not have duplicates so it must be visible in the text by encrypting
    report its presence (1 time only) or all the characters this one
    both in the text after eliminating pressent characters several times, remains in the form code.
    adqtuy / egil / pjkn / obfxzh
    (1 time) / (2 times) / (3 times) / (4 5 8 9 times)
    (A d t q u y) once in the text
    9 9 9 9 8 8 8 8 7777 6666 = 5555 4444 3333 2222 1111
    adqtuy - - - - - - - - - - -----------------------------------
    Example: 1234567890123456 = 78900987654321987654
    or 1111111111111111 = 11111111111111111111
    or 1111777511456421 = 66880044411009922336
    and the first digit has a different value of the second and so on. .... So the first 1 will be A, B will be 1 second and so on, more characters to scramble.
    So with 10 digits and can not exceed 255 reduces its encryption.
    Converted to decimal 0 = 48 and 30 in Hexa
    255: 30 = 9 MAX 255: 48 MAX = 6
    9 converted to decimal = 57 and 39 in Hexa
    255: 39 = 7 MAX 255: 57 = 65 MAXI
    So the division, subtraction, multiplication will not be used and still adding
    that may serve, by inference we can easily find its encryption method.
    Permuting rest but will have identical characters and easily detectable.
    or the formula in exel and must be tested from 0 to 255.
    EXEL SOUX = ((0 * C86/256)-T (0 * C86/256)) * 256
    EXEL SOUX = ((255 * C86/256)-ENT (255 * C86/256)) * 256
    Which are coded and which are repeated, have tested the formula in exel there are chances of
    Find a match and that number is found the rest will be easy.
    I clear the text and I encrypt the text, and my friend only encryption key but
    do not know the plaintext
    Its key it can decrypt and discover the plaintext, I guess it is not
    also complicated, because the figures have the same value once encrypt
    Example: A value will b 5, an R-value will be 0 ... etc ...
    So they will not take the value of another figure, and will not be repeated
    in the encrypt text, it will always be one (b for 5) and no other (b)?
    significantly reduced its combinations.
    On the forums:
    Simply because this key will affect the interference characters by their ASCII value.
    ASCII codes represent the letters A to Z (eg "A" is 65, "B" is 66, ...) and all the figures and the other symbols on your keyboard.
    But the problem is that ASCII values range from 0 to 255.
    The most important part of encryption is the way to blur the text.
    ASCII does not constitute an encoding of secret is to encrypt the ASCII code
    Encryption using the following:
    C note on the encryption feature which, at any integer n in [0, 255] combines the remainder of the division by 256 of 7n. Let C (n) the rest. We use the formula "= MOD (7 * n, 256).
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
