The DS1820 Wait time mystery ...
Results 1 to 1 of 1
    Lightbulb The DS1820 Wait time mystery ...
    Finally ... I got it !!!
    The famous waiting loop
    While DQ : WEND
    never loops !!!
    You comment it ... the reading continues to work as it ... Strange ???
    NO,
    In fact, you ask for the conversion ... and read the scratch pad.
    Two different things : you'll read the same value on the scratchpad UNTIL the end of conversion ... overwrites the scratchpad.
    Asking for a new conversion while previous still running do not disturb the chip at all ... it ignores the command !!!
    so, no waiting required ... but it's not "real time measurement"
    How to be sure what you read is the result of the last demand ???
    You must ASK the device for "still busy" by sending it a short LOW "request pulse" ... and then you have 15 µs for reading the bus ... NO MORE !!!
    Externally ... the bus is released as soon as the convert command has been sent ... so you must send request pulses as long as the chip answer is NOT "0".
    see :
    ' Check for still busy converting
    waitloop:
    	 LOW DQ              ' Pulls the bus LOW
    	 INPUT DQ            ' Releases the bus and prepare reading
    	IF NOT DQ THEN    ' If bus kept low
    	 PORTC.4 = 1        ' Show it
    	 GOTO Waitloop     ' Go on asking device state
    	PORTC.4 = 0         ' clear marker
    Here ... what's printed is what you have asked for ... not previous readings ...
    This one Works fine too
    waitloop:
    OWIn DQ, 4, [Busy] ' Check for still busy converting
    If Busy = 0 Then
     PORTC.4 = 1
     GOTO waitloop
    PortC.4 = 0
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. HARDWARE I2C SAMPLE CODE question
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 13:12
  4. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
  5. DS1820 again
    By paxmowa in forum mel PIC BASIC Pro
    Last Post: - 10th January 2006, 14:49
