Possible to rebuild digital servo?
Results 1 to 9 of 9
    Default Possible to rebuild digital servo?
    Hi all!
    I have rebuilt a analog servo to do a continuous rotation.
    Now i need some servos to a robot project and have found a cheap servo at hobbycity.com. The servos i would like to use are the HXT12K servos, but they are stated as digital.
    Is it possible to rebuild a digital servo the same way as a analog?
    Question ??? why complicate things ?
    Hi, Robert
    Your question is somewhat fuzzy ...
    Yes, You can change "digital" ( lol ) servo electronics for an analogic "old" one.
    Yes you can find some DIY digital electronics on the Web ... but it doesn't seem to be what you intend to do ...
    But you won't get any advantage in such rebuilt ... a "HongKong" servo always will stay " no so good " ...
    And it' somewhat funny to adjust the amplifier parameters to the mechanics !!!
    Have fun
    Hi, Robert
    Have fun
    Tank you for the reply!
    I try to clarify.
    I want to rebuild a digital servo so that it can turn 360 degrees (not make it analog ) , rotate continuously that is. The servo that i already rebuilt was a "analog" type. The procedure to make it spin was to remove a pot and repalce it with two resistors and also a gear had to be modified.
    My question is if a "digital" type servo can be rebuilt in the same way? Does it also use a pot to "read" its current position?
    Wink
    Ok, I see
    At first sight, no difference for the conversion. "Digital" servos only have digital electronics ... to the day.
    Always the good ol' position pot.
    Just think if the signal passes the "Digital" limits ... rotation will stop !!!
    Sep 2009
    Default I've successfully rebuild these servos to continuous rotation
    Here is some foto's:
    http://roboforum.ru/viewtopic.php?f=8&t=6700
    I can translate text to english (my poor english ) if needed.
    Nice
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. saving RCREG to word
    Last Post: - 15th September 2008, 14:51
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 22:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
