LCD R/S works on Port A but not Port B
Results 1 to 5 of 5
    Jan 2008
    Carrollton, TX
    Default LCD R/S works on Port A but not Port B
    Have been trying on both a 16F627A and now a 16F84A'
    The first code below works, but when I switch the R/S pin from PortA.2 to Port B.2, I get a blank LCD screen. I can't see what I'm doing wrong. Can anyone help?
    LCD Display
    ' The connection between the LCD display and the microcontroller is as follows:
    ' Display Microcontroller pin
    ' DB4 RB4
    ' DB5 RB5
    ' DB6 RB6
    ' DB7 RB7
    ' E RB3
    ' RS RA2
    ' Compiler: PicBasic Pro
    ' Modifications
    ' DEFINITIONS
    define LCD_DREG PORTB
    define LCD_DBIT 4
    define RSREG PORTA
    define LCD_RSBIT 2
    define LCD_EREG PORTB
    define LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    TRISA = 0 ' Register A pins are outputs
    TRISB = 0 ' Register B pins are outputs
    PAUSE 500 ' Wait 0.5sec for LCD to initialize
    OPTION_REG = $80
    LCDOUT $FE, 1 ' Clear LCD
    LCDOUT $FE, $C0
    LCDOUt "ClockWorks"
    The following does not work:
    ' LCD Display
    ' DB4 RB4
    ' DB5 RB5
    ' DB6 RB6
    ' DB7 RB7
    ' E RB3
    ' RS RB2
    ' Modifications
    ' DEFINITIONS
    define LCD_DBIT 4
    define RSREG PORTB
    define LCD_RSBIT 2
    define LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    OPTION_REG = $80
    LCDOUT $FE, $C0
    LCDOUt "ClockNot"
    TDon
    Try adding this to your code. FLAGS=0 and for the 627A add cmcon=7 to disable the comparators on portA. It is just me but I would initialize the Ports before the Tris with PortB = 0 and PortA = 0 and lose this: OPTION_REG = $80. OPTION_REG = $80 sets WPU when portB is set as input, since you are using it as outputs, it is not needed.
    You've screwed up your defines...
    Instead of...
    Define LCD_RSREG PORTB
    you've written...
    define RSREG PORTB
    PICBasic doesn't error on define typo's, and you must have chosen the default setting in the option that works.
    Instead of...
    you've written...
    define RSREG PORTB
    SHARP EYES ! Good catch.
    Jan 2008
    Carrollton, TX
    Thanks Melanie and Joe,
    And I had even read Melanies post about not screwing up the DEFINE statements!
    What happened was that I had copied some defines from the pbppic14.lib file and then modified them for PBP, but I missed changing them to upper case.
    This is a good example of why you should post your code when you ask a question. No telling how long it would have taken me to find that.
    thanks again
    TDon
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD works at 4MHz, but not 12 or 16MHz
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 01:23
  5. Running an LCD on different port
    Last Post: - 18th December 2006, 06:41
