Parsing Strings...
Results 1 to 24 of 24
    Feb 2009
    That was the way I read the manual as well. I thought that as soon as the function saw a character meeting the WAIT criteria it would terminate collecting any more characters. In fact what I'm seeing is that it continues to gather all 5 characters, so it collects the comma as well if the string is less than 5!
    The manual says the string length is determined by the count OR when the optional character is encountered. Unfortunately that sentence can be interpreted two ways.
    Played with this some more...
    Without a qualifier for some reason the buffer keeps the last data sent and returns it with the next. I guess you do not have a qualifier at the beginning of the string so use the LF or CR at the end.
    This is what I am sending
    123456789,987654321
    and I have my terminal set to terminate the line with a CR LF.
    The working code
    <html>
    <head></head>
    <body><!--StartFragment--><pre><code><font color="#000080">
    '18F6680   02/14/09  INFEED PARSE TEST BAUD 9600
        </i></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>OSC </b></font>20
        @ <font color="#0000FF"><b>__CONFIG    _CONFIG1H</b></font>, <font color="#0000FF"><b>_OSC_HS_1H
        </b></font>@ <font color="#0000FF"><b>__CONFIG    _CONFIG2H</b></font>, <font color="#0000FF"><b>_WDT_ON_2H </b></font>&amp; <font color="#0000FF"><b>_WDTPS_128_2H
        </b></font>@ <font color="#0000FF"><b>__CONFIG    _CONFIG4L</b></font>, <font color="#0000FF"><b>_LVP_OFF_4L
        </b></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_DREG     PORTG
        </b></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_DBIT     </b></font>0
        <font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_RSREG    PORTE
        </b></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_RSBIT    </b></font>0
        <font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_EREG     PORTE
        </b></font><font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_EBIT     </b></font>1
        <font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_BITS     </b></font>4
        <font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_LINES    </b></font>4
        <font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_COMMANDUS    </b></font>3000
        <font color="#FF0000"><b>DEFINE </b></font><font color="#0000FF"><b>LCD_DATAUS   </b></font>150
      <font color="#000080"><i>'###############################################
        </i></font><font color="#FF0000"><b>PAUSE </b></font>100 : <font color="#FF0000"><b>LCDOUT </b></font>$FE,1,<font color="#00FF00"><b><i>&quot;TEST&quot;
        </i></b></font><font color="#0000FF"><b>N1 </b></font><font color="#FF0000"><b>VAR LONG</b></font>:<font color="#0000FF"><b>N2 </b></font><font color="#FF0000"><b>VAR LONG
        </b></font><font color="#0000FF"><b>START</b></font>: <font color="#0000FF"><b>N1 </b></font>= 0 : <font color="#0000FF"><b>N2 </b></font>= 0
        <font color="#FF0000"><b>HIGH </b></font><font color="#0000FF"><b>PORTG</b></font>.4 :<font color="#FF0000"><b>PAUSE </b></font>250:<font color="#FF0000"><b>LOW </b></font><font color="#0000FF"><b>PORTG</b></font>.4
        <font color="#0000FF"><b>RCSTA</b></font>.4 = 0 : <font color="#0000FF"><b>RCSTA</b></font>.4 = 1
        <font color="#000080"><i>'CHANGE LINE FEED AND CARRIAGE RETURN AS REQUIRED
        </i></font><font color="#0000FF"><b>RCSTA</b></font>=$90:<font color="#0000FF"><b>TXSTA</b></font>=$24:<font color="#0000FF"><b>SPBRG</b></font>=129:<font color="#FF0000"><b>HSERIN</b></font>[<font color="#0000FF"><b>WAIT</b></font>($a),<font color="#0000FF"><b>WAIT</b></font>($d),<font color="#FF0000"><b>DEC </b></font><font color="#0000FF"><b>N1</b></font>,<font color="#0000FF"><b>WAIT</b></font>(<font color="#00FF00"><b><i>&quot;,&quot;</i></b></font>),<font color="#FF0000"><b>DEC </b></font><font color="#0000FF"><b>N2</b></font>]
        <font color="#FF0000"><b>LCDOUT </b></font>$FE,1,<font color="#FF0000"><b>DEC </b></font><font color="#0000FF"><b>N1 </b></font>: <font color="#FF0000"><b>LCDOUT </b></font>$FE,$C0,<font color="#FF0000"><b>DEC </b></font><font color="#0000FF"><b>N2 </b></font>: <font color="#FF0000"><b>GOTO </b></font><font color="#0000FF"><b>START
    </b></font></code></pre><!--EndFragment--></body>
    </html>
    Feb 2009
    Hi Dave,
    I think your latest solution might have worked, but I had already got it working by parsing it after the fact based on Jersons parse routine. I really appreciate everyones input. Here is what the working code looks like:
    hserIN 65535, oops, [STR inputdata\12\10] 'get the serial data
    gosub ParseNumber 'split the raw data into 2 numbers
    ParseNumber: ' collect both pieces of the data in sep arrays
    for Cntr = 0 to 10
    if inputdata[Cntr] <> "," then ' Found comma? We've got first
    smallp[Cntr] = inputdata[Cntr]
    Cntr2 = Cntr 'marks where the comma was
    'goto earlyexit
    goto GetNum2 ' Now get the second number
    next
    earlyexit:
    GetNum2:
    CNTR = Cntr + 1 'get past the comma
    for Cntr = Cntr to 10
    if inputdata[Cntr] < "0" then
    If inputdata[Cntr] > "9" then
    largep[Cntr-Cntr2-1] = inputdata[Cntr] ' It's a valid number
    next
    I had to modify the array pointer for the second number by subtracting the point at which the comma was found on the first pass from it's pointer. In other words the pointer for the input data can't be used directly to point to the second number.
    <b>Proof Again</b> There is more than 1 right way to do almost everything.
  1. Parsing serial data
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 15:25
  2. Please help with storing strings in codespace
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 02:02
  3. How to write/read strings EEPROM/LCD
    Last Post: - 11th February 2007, 07:26
  4. Processing lengthy strings
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st March 2006, 06:27
  5. I2CWRITE writing Strings to EEPROM
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 27th March 2005, 20:45
