Parsing Strings...
Results 1 to 24 of 24
    From the manual:
    STR followed by a byte array variable, count and optional ending
    character will receive a string of characters. The string length is
    determined by the count or when the optional character is
    encountered in the input.
    [STR smallp\10\,]
    See if that will get the first part correctly.
    Does the data comming in have a qualifying character before the data you want? If so then the first example I gave will work. If it does not have a qualifying character then leave that part out.
    Feb 2009
    I appreciate your help! Very confused
    hserIN 65535, oops, [STR smallp\10\","]
    The first time thru I get the correct first part of the string. the device was sent 777,53 and smallp received 777.
    The second time and every time thereafter the data is skewed. For example if the next packet that comes in is 766,59 smallp receives a 53766. The 53 from the last packet sent....
    Sep 2005
    Campbell, CA
    It would seem to be a lot easier to capture the whole sequence, then later scan the array for any commas and deal with it that way, especially since when you are using SERIN you have very little processing time available between characters.
    Charles Linquist
    Feb 2009
    I think that's a great suggestion and I agree. I have been unable to successfully parse it after the fact.
    Feb 2009
    and to make matters worse I am unable to consistantly and correctly receive serial packets.
    Feb 2009
    Well, I got the serial function working reliably by doing this:
    hserIN 65535, oops, [STR smallp\12\10]
    rather than this:
    hserIN 65535, oops, [STR smallp\12\13]
    aparently the linefeed was the last command sent, so by terminating with a carraige return, the linefeed that followed was polluting the serial stream for the next packet
    Feb 2009
    So now that I'm just looking at a parsing issue I've changed the serial in code to:
    hserIN 65535, oops, [STR smallp\5, WAIT(","), STR largep\5\10]
    It doesn't work as expected. When receiving 1480,95...
    STR smallp\5 actually captures 5 characters including the comma even though it's the "wait for" character. I can't make smallp\4 because sometimes the data received will be 5 characters. It could also be 3 or 2 or 1 characters.
  1. Parsing serial data
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 4th March 2010, 15:25
  2. Please help with storing strings in codespace
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 02:02
  3. How to write/read strings EEPROM/LCD
    Last Post: - 11th February 2007, 07:26
  4. Processing lengthy strings
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st March 2006, 06:27
  5. I2CWRITE writing Strings to EEPROM
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 27th March 2005, 20:45
