LONG Data type
Results 1 to 5 of 5
Thread: LONG Data type
    Feb 2009
    Default LONG Data type
    Hi everyone,
    I recently purchased PicBasic Pro and am digging deep into a new design. So far I have found it amazing as a rapid development tool. Unfortunately the manual documentation leaves a lot to be desired...
    Anyway, I have need for a LONG Data type for a number that will sometimes exceed what is achievable in 2 bytes. I attempted to define a variable as Long but the compiler does not see it as a valid data type. I know when I was reading up before I purchased PBP that version 2.50 supports Longs.
    Please advise what I am doing wrong.
    TR
    You have to use PBL and you must be using 18F series chips, you select PBL in the compiler options menu under view.
    Feb 2009
    Default Thanks Joe!
    Thanks Joe!
    It worked after selecting the "Use PBL" button under the view menu as you instructed.
    So, what is PBL?
    TIA
    TR
    The L in PBL stands for LONG.
    You have the option to compile for Long usage or regular. If you do not need Longs then compile with the regular as code compiled with PBL is larger.
    Feb 2009
    Default Aha..
    Aha...
    Thanks for that tidbit!
  1. Using Nokia LCD
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    By Don Mario in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 00:56
