How to embed user ID into PIC
Results 1 to 11 of 11
    Aug 2008
    Question How to embed user ID into PIC
    I would like to know how to embed the user ID using PBP? Can I use poke above memory 1FFFH?
    Wink
    From µChip MPLAB Programmers HELP :
    ID Location : Program or verify the User ID. You can set the User ID by selecting Configure>ID Memory.
    From '628 Datasheet
    14.10 User ID Locations
    Four memory locations (2000h-2003h) are designated
    as user ID locations where the user can store
    checksum or other code-identification numbers. These
    locations are not accessible during normal execution
    but are readable and writable during Program/Verify.
    Only the Least Significant 4 bits of the user ID locations
    are used for checksum calculations although each
    location has 14 bits.
    I'd recommend you to read The MPASM Help chapter relative to "__idlocs" ...
    I will become obvious for you, then ... even if you have a "non µChip" programmer.
    deuhhh, yes there's an easier way.... Always nice to read MPASM PDF
    Wasn't it called " RTFM " in the good ol' Forum times ...
    Quand la censure ne coupait pas systématiquement tout ce qui pouvait ressembler à de l'humour ...
    Mheuuuuunoon, je l'ai pas dit ...
    hasquetèkon
    Now I would ask, how do you read these ID location in PBP?
    From MPASM
    Usage
    This directive is used in the following types of code: absolute or relocatable. For information on types of code, see Assembler Operation.
    This directive is not commonly used, but does provide an easy method of serializing devices. __idlocs can be read by a programmer. PIC18 devices can read this value at run-time, but PIC12/16 devices cannot.
    For PIC18, I guess Darrel have the right ticket for that. Something based around the following
    http://www.picbasic.co.uk/forum/showthread.php?t=4093
    I found this snip on Microchip website
    	// read serial number from PIC ID memory at address 0x200000 - 0x200007
    	DWORD ReadIDMemory(void) {
    	DWORD IdMemory=0;
    	DWORD Temp;
    	BYTE i;
    	TBLPTR = (unsigned short long) 0x200000;
    	for(i=0;i<8;i++) {
    		_asm
    		TBLRDPOSTINC
    		_endasm
    		Temp=TABLAT;
    		Temp<<=((7-i)*4);
    		 IdMemory+=Temp;
    	return IdMemory;
    I find these a little complicated and limited to 18 series.
    My good old programmer, (ELNEC PIKprog+), is doing this serialization in a very good manner. Also gives an option where to store the serial number, so one can choose to store in EEPROM or Code space. Reading then is childs play.
    Ooh, and it counts automatically of course with programmable step.
    I'd like though to have this option on my ICD2. Maybe one day Microchip will do it. Hope I am alive then!
    It is limited to PIC18 only if you want to access it at RunTime, unless most programmer are capable of reading the IDLOCS. And as you say, some also offer the automatic serialization, a nice plus.
    Aug 2008
    Thumbs up
    Alright, I manage to get it to work now. Thanks for the info guys.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  3. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 23:47
  4. Serial Pic to Pic using HSER
  5. pic basic pro (novice user)
    By f6ggy in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2003, 14:29
