I2C With 3,3 Volt
Results 1 to 10 of 10
    curious, but doesn't PBP run the clock and data as open collector? (playing with tris).
    the 628a doesn't have i2c hardware so would have to be done by PBP.
    as I've seen the define to make the clock bipolar I've wondered about that.
    and reading the lib seen :
    i2chigh
          ifndef I2C_INTERNAL
            bsf     FSR, 7          ; 1 Point to TRIS
            iorwf   INDF, F         ; 1 Set high (input)
    or similar all about the i2c routines.
    if so, then pullups to 3.3v appears to be all that's needed.?
    (assuming the pic recognises 3.3v as a high)
    maye that's why Acetronics said
    But just verify you use TTL inputs of the PIC and not Schmitt trigger ones ...
    Something I'm missing?
    Hangover, Germany
    Cool
    You need a bidirektional Level-shifter !
    Look here:
    http://www.standardics.philips.com/s...df/an97055.pdf
    http://www.semiconductors.philips.co...#levelshifting
    You need only 2 little MOSFETs!
    Jun 2006
    Default final works
    Yesterday i test it and all is ok.
    I use 5volt for 16f628a + LCD and 3,3 volt for NS73M
    My problem with NS73M is that have spurius near the local frequency.
    Thanks all for help.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. PIC16F877 I2C programme
    By cooqo in forum mel PIC BASIC
    Last Post: - 21st April 2008, 11:02
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
