shared data lines for LCD and LED'S?
Results 1 to 5 of 5
    Bombay, India
    Your thought processes seem to be right. I could suggest that you write to the LCD within the interrupt during the interdigit blanking period. Doing the LCDout outside the interrupt may give you wierd results when there is a clash between the LCDout code and the LED code. Assuming you disable interrupts for an LCDout, there may be a visible flicker in the LED which may be bearable or even irritating depending on the severity.
    To write to the LCD inside the interrupt, you could signal the write after preparing a message. The interrupt code would then handle the write and you will not see a perceptible flicker.
    This technique is usually used in small microcontrollers to multiplex 7segment LEDs with upto 8 keys.
    Have you looked at 16F914?
    Talking Groovy!
    Thanks, I just wanted to see if there was something obvious I was missing.
    The lcd is one of the standard hd4470? parallel 2 line types, so I don't think the 16f914 is going to help me there, funny you mention it though, as I just recieved some 917's and 946's (same family)
    Thanks again for the input.
    lol, now that I asked I found in microchips App note AN234, (Hardware Techniques for PICmicro Microcontrollers)... there's a section about sharing LCD data lines for other i/o.
    day late dollar short? :-) time to at least browse all the app notes.. some darn good stuff in there..
  1. i cant get 18f2550 work as HID
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 17:39
  2. Going Loopy - How do i get my Loops sorted out ???
    By gtvmarty in forum mel PIC BASIC Pro
    Last Post: - 24th September 2009, 06:02
  3. Use of a PIC
    By Edwardo in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 15:11
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. controlling leds with the switches
    By ilteris in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 22:02
