Cordic trig assembly code for PIC18f
Results 1 to 40 of 55
    Aug 2003
    Uh-oh.. just including the line:
    include "trig-pic16.inc"
    causes this:
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 213 : [235] Opcode Expected Instead of 'dt'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 216 : [235] Opcode Expected Instead of 'dt'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 219 : [235] Opcode Expected Instead of 'dt'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 222 : [235] Opcode Expected Instead of 'dt'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 237 : [226] Numeric Constant or Symbol Name Expected
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 239 : [226] Numeric Constant or Symbol Name Expected
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 269 : [235] Opcode Expected Instead of 'movfw'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 283 : [235] Opcode Expected Instead of 'movfw'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 301 : [235] Opcode Expected Instead of 'movfw'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 306 : [235] Opcode Expected Instead of 'movfw'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 316 : [235] Opcode Expected Instead of 'movfw'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 321 : [235] Opcode Expected Instead of 'movfw'
    Error C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 349 : [235] Opcode Expected Instead of 'movfw'
    Warn C:\PROGRA~1\MPLAB\PROJECT\SCROLL.ASM 934 : [102] Code Crosses Boundary @ 800h
    I'm using a 16F877 too.
    Use MPASM for the assembler.
    Aug 2003
    Thanks Darrel,
    I'm working on hardware now, but I'll try again as soon as possible.
    Any idea on my first question?
    Aug 2003
    It seems that this line becomes offensive:
    '@ DEVICE LVP_OFF,BOD_OFF,HS_OSC				'
    Which is how I set configuration.
    Art.
    You need to use a different syntax for MPASM.
    like this:
    Example: To set the PIC for Internal Oscillator allowing use of the OSC pins as I/O...
    @ __config _INTRC_OSC_NOCLKOUT
    Only one config statement is allowed when using MPASM, so multiple definitions follow-on from each other each connected to it’s previous buddy with an &.
    Example: Typical Settings for a 16F628…
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_ALL & _DATA_CP_ON
    More (much more) here: http://www.picbasic.co.uk/forum/showthread.php?t=543
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:55
  5. Your Suggestions: Assembly code material?
    By dw_picbasic in forum General
    Last Post: - 2nd February 2007, 18:33
