Cordic trig assembly code for PIC18f
Results 1 to 40 of 55
Threaded View
  1. #22
    That is the hardest part. Darn radians are 90 degrees off from the start.
    For example
    0 = 90 degrees
    5461 = 60 degrees
    10922 = 30 degrees
    16383 = 0 degrees (or North)
    21844 = 330 degrees
    32767 = 270 degrees
    38228 = 240 degrees
    and so on.....
    You definitely do not have to know this, but I think it is interesting:
    In the time it takes for a regular Sin, or Cos 16 bit function on a PIC18 to give a result, light travels 3000 kilometers
    The time it takes for this cordic 16 bit result, light travels 33.3 kilometers.
    How do you say "Your mileage may vary" when you use kilometers?
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 23:55
  5. Your Suggestions: Assembly code material?
    By dw_picbasic in forum General
    Last Post: - 2nd February 2007, 17:33
