Cordic trig assembly code for PIC18f
Results 1 to 40 of 55
Threaded View
  1. #3
    Hi Walter,
    I thought we had this working already.
    Here's one thing I see...
      ; Set up the main loop
    sc_loop_start:
      clrf i
      banksel atans
      lfsr FSR0, atans
    banksel will put it in the proper bank for a variable in RAM.
    But he's trying to use it with with a Label in FLASH.
    I'm sure it was just a mistake on his part because the lfsr is correct.
    And with his ASM code at the very beginning, it probably would have come up with bank 0 without him even knowing it.
    However, now that it's in an include file for PBP, that atans table will be at a much higher address in Flash and you'll end up in a different bank than where the variables are.
    Just comment it out.
    I was only 1/3 of the way thru when I found that.
    If it doesn't help, let me know, I'll keep looking for more.
    P.S. You should specify BANK0 for all the variables used with this routine.
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 23:55
  5. Your Suggestions: Assembly code material?
    By dw_picbasic in forum General
    Last Post: - 2nd February 2007, 17:33
