Strange happenings PBP and 12F683
Results 1 to 15 of 15
    Omaha, Nebraska USA
    Joe, the switch drives an optoisolator which in turn drives the PIC input (GPIO.3 configured as input, not MCLR). (I've looked at the switch and the output from the opto on the scope; there's not much bounce.)
    Alain, my general arrangement of the program is:
    PROGRAM (things done at power-up only)
    MAIN LOOP (you've seen it)
    SUBROUTINES (you've seen the one that is the problem)
    INTERRUPT HANDLER
    I'll try moving some things around, but I continue mystified and frustrated.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Wink
    Hi, Russ
    I do not have any problem left with :
    INTERRUPT HANDLER
    END ( for safety ...)
    and @ last prog memory location
    @GOTO Program ( if "not so good" supply ... EQU : Prog Pointer lost )
    Omaha, Nebraska USA
    Default The whole nine yards
    Okay, here's the latest, in full.
    It works just fine.
    I had hoped to also have a flag called MFLAG at EEPROM address 255, managed in a manner similar to what is done with PFLAG.
    If MFLAG is 0, the program would be prevented from looping when the trigger (TRIGR) is still being held high (on). But it doesn't matter where I put IF . . . ENDIF or WHILE . . . WEND or GOTOs or GOSUBs. Whenever they are dealing with TRIGR, I get glitches.
    So I'm posting the whole thing. Maybe one of you can see what prevents me from getting what I need to do in a manner that will work.
    Russ
    Hi, Russ
    If the key is stuck or still held down, I want further execution to stop until the key is released.
    generally, I do that :
    ' Test Sélection
    Delay	= 0
    BUTTON Selection,0,255,0,Delay,1,Wait1     ' button pressed pulls to ground
    	GOTO Affichage                          ' or Wherever you want, if no press !
        ' rem: NO DELAY if test = 0 !!!
    Wait1:                                                   ' Wait for release
    	Delay = 0
    	GOTO Affichage                          ' Here, we continue ONLY if Button has been released ...
    Bombay, India
    Wouldn't this work? You have it in Erase already.
    MAIN:   IF TRIGR=1 THEN
                PAUSE 10
                GOSUB PLAY
                while TRIGR=1:wend                   'block till the key is released
            IF CONTROL=0 THEN
                PAUSE 10
                GOSUB RECORD
                while CONTROL=0:wend                   'block till the key is released
            IF ACTIVE=0 THEN
                PAUSE 10
                GOSUB MANUAL
                while ACTIVE=0:wend                   'block till the key is released
            GOTO MAIN
    Last edited by Jerson; - 7th February 2009 at 13:32. Reason: formatting with [code]
    Omaha, Nebraska USA
    Lightbulb I think I solved it . . .
    Thanks, Jerson and Alain. I'll keep both of those ideas in mind.
    What I ended up doing that worked: Inspired by part of what Charles said, I check the condition of the switch in the interrupt handler and set a flag if the switch is closed. Then I check the flag during the MAIN loop. If it and another flag are both set, it kicks to a subroutine.
    But nothing yet explains why I couldn't dependably perform simple conditionals on that input in the MAIN loop. It's a mystery.
    Russ
    Omaha, Nebraska USA
    Default Still an occasional problem
    I've attached the most recent version.
    Once in a while, for no apparent reason, or after a RECORD cycle, when TRIGR is activated (with MFLAG set to 0), the program appears to jump directly to NOTCLR.
    How long does the interrupt service in TIMER take? I'm sure it's a matter of microseconds, but how many using DT_INTS-14?
    Is it possible that, if TRIGR goes high during the very short time while the interrupt is being serviced, the routine is going to skip going to PLAY and instead will go to NOTCLR?
    And, if so, what is the best solution?
    Russ
  1. How to use LM34 to full range with PBP
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 9th January 2010, 14:43
  2. New to PBP
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 12th May 2009, 17:24
  3. New project help rapidfire on 12f683
    By thm ov3rkill in forum mel PIC BASIC Pro
    Last Post: - 27th December 2008, 20:59
  4. 12F683 HPWM Usage
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 03:16
  5. upgrade to PBP 2.46 and using 12F683
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2005, 08:13
