Matrix _16f877 need help, please
Results 1 to 12 of 12
    May 2008
    Italy
    Since you didn't use a limiting resistor, you have fried the pic!
    Replace it and put a 330 ohms resistor in series to every leds. Then use Joe snippet, given in post # 2 and you will see that leds will switch on and off without burning another pic.
    You will always read 1.6 - 1.7 V across a led, unless you have shorted one!
    Al.
    Apr 2008
    hello Arrati,
    yes I have 200 ohms resistors connected in serial with each input of the PIC to limit the current into the pic.
    I guest some thing wrong, because when I use OHM meter to test the LEDs. at the two pins on the socket (removing the PIC out of the socket) every thing is ok! so the circuit is not open.
    I try to figure out
    thanks for your comment.
    Minh le
    Apr 2008
    Red face
    hi every boDy,
    I removed the two capacitors of the X-TAL OSCILLATOR then it works. i am sorry for long time not to post the reply
  1. led matrix pic 16f84 and 4017 help me please
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 5th February 2011, 01:06
  2. RGB LED Matrix
    By ERIK in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 08:01
  3. LED Matrix Question
    By mekohler in forum Schematics
    Last Post: - 29th September 2007, 14:12
  4. 4x16 Dot Matrix LCD control is possible?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 10:56
  5. need help with switch matrix
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2005, 19:59
