open DT_INTS-14.bas file, there you'll find
So, just modify it as requestedCode:' --- IF any of these three lines cause an error ?? ---------------------------- ' Comment them out to fix the problem ---- ' -- It depends on which Chip you are using, as to which variables are needed -- wsave1 var byte $A0 SYSTEM ' location for W if in bank1 wsave2 var byte $120 SYSTEM ' location for W if in bank2 wsave3 var byte $1A0 SYSTEM ' location for W if in bank3
Code:' --- IF any of these three lines cause an error ?? ---------------------------- ' Comment them out to fix the problem ---- ' -- It depends on which Chip you are using, as to which variables are needed -- ;wsave1 var byte $A0 SYSTEM ' location for W if in bank1 ;wsave2 var byte $120 SYSTEM ' location for W if in bank2 ;wsave3 var byte $1A0 SYSTEM ' location for W if in bank3
