Serial and interrupt
Results 1 to 21 of 21
    Feb 2009
    The thing is that it's kinda to late to change the pic for my current project
    Well it seems that I will be coding my own serial routine after all...
    In what way is the debugIN function different except the syntax?
    Do you have some more info about instant interrupt? Something to get me started.
    Anyway thanks for the help
    DEBUGIN works better on higher baudrate on Slower Speed OSC. Check your manual about that. Syntax is a bit different as well.
    Instant-Interrupt
    http://darreltaylor.com/DT_INTS-14/intro.html
    Feb 2009
    Before posting posting to this forum I tried "DT_INTS-14" but I got some compailing errors, any idea how to fix them?
    wsave3 position request 416 beyond RAM_END 95
    wsave2 position request 288 beyond RAM_END 95
    wsave1 position request 160 beyond RAM_END 95
    Unable to fit variable RS2_Save
    open DT_INTS-14.bas file, there you'll find
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    So, just modify it as requested
    ;wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    ;wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    Feb 2009
    So I did and now there's only one error left...
    well, seems we hit one of the limitation of the low-end PIC. In this case, asm INT and home made serial routine would work. 12F683 would provide better range.
    Let's see what Darrel would suggest...
    Feb 2009
    I suppose that the only way to write the serial routine is to code it in asm.
    Damn me for choosing this somewhat limited pic
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. 18F2480 asm interrupt
    By Richard Storie in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 20:40
  3. Serial and Port B interrupt
    Last Post: - 6th November 2008, 17:22
  4. timer and serial interrupt
    By yourmomOS in forum mel PIC BASIC Pro
    Last Post: - 14th July 2006, 19:02
