Serial and interrupt
Results 1 to 21 of 21
    Feb 2009
    Default Serial and interrupt
    How do one use a interrupt with the SERIN function? Basically what I'm trying to accomplish is to have a blinking LED and an interrupt on porta.5 - where I retrive a byte and then continue with the main loop.
    Currently my code isn't working as expected. It seems that the interrupt doesn't resume the main program loop after SERIN.
    I'm compiling for pic12f629.
    btw, to be able to do multitasking (updating LEDS and receiving from serial port) do I need to use interrupts?
    INCLUDE "modedefs.bas" 'For the Baud Rate modes
    char var byte
    ON INTERRUPT GOTO myint ' Interrupt handler is myint
    INTCON.3 = 1 'PORTA change interupt enabled
    INTCON.7 = 1 'Global interrupt enabled
    IOC.3 = 1
    led_on:
    high porta.0
    low porta.0
    goto led_on
    ' Interrupt handler
    DISABLE ' Disable interrupts in handler
    myint:
    SerIN PORTA.3, T9600, ["b"],char    ' Will be uesed later
    INTCON.0 = 0 'Clear GPIF
    RESUME ' Return to main program
    ENABLE ' Enable interrupts after handler
    You just don't want to use a Software bit banged solution with interrupt. Move on a PIC with Real Hardware USART and use USART inetrrupt.
    It might be doable with your PIC, but on slower baudrate, using ASM interrupt (maybe instant interrupt), and an home made serial routine. No way this might work 100% properly with ON INTERRUPT even more with internal OSC.
    You could still try something and reduce your delay, using short PAUSEUS loop might work better.
    Using DEBUGIN would also help.
    If you build yourself the Master you could send few garbarge data, then a Synch character, then your data. Says
    SEROUT2 ....[REP 0\32, "~", YourData]
    on the receiver side you just use WAIT("~") ... might work.....
    Feb 2009
    The thing is that it's kinda to late to change the pic for my current project
    Well it seems that I will be coding my own serial routine after all...
    In what way is the debugIN function different except the syntax?
    Do you have some more info about instant interrupt? Something to get me started.
    Anyway thanks for the help
    DEBUGIN works better on higher baudrate on Slower Speed OSC. Check your manual about that. Syntax is a bit different as well.
    Instant-Interrupt
    http://darreltaylor.com/DT_INTS-14/intro.html
    Feb 2009
    Before posting posting to this forum I tried "DT_INTS-14" but I got some compailing errors, any idea how to fix them?
    wsave3 position request 416 beyond RAM_END 95
    wsave2 position request 288 beyond RAM_END 95
    wsave1 position request 160 beyond RAM_END 95
    Unable to fit variable RS2_Save
    open DT_INTS-14.bas file, there you'll find
    ' --- IF any of these three lines cause an error ?? ----------------------------
    ' -- It depends on which Chip you are using, as to which variables are needed --
    wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
    So, just modify it as requested
    ;wsave1      var byte    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2      var byte    $120    SYSTEM      ' location for W if in bank2
    ;wsave3      var byte    $1A0    SYSTEM      ' location for W if in bank3
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. 18F2480 asm interrupt
    By Richard Storie in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 20:40
  3. Serial and Port B interrupt
    Last Post: - 6th November 2008, 17:22
  4. timer and serial interrupt
    By yourmomOS in forum mel PIC BASIC Pro
    Last Post: - 14th July 2006, 19:02
