having problems to read a PIC16F877
Results 1 to 5 of 5
    Feb 2009
    Default having problems to read a PIC16F877
    hi everyone, i am trying to read a PIC16F877 that is on a general control board which controls an engine. there is also a lattice fpga on this board. the thing is that i am trying to read the program that is on the pic device to modify a few things. but the VDD pin on the connector has been cut, is there any kind of modification that i can do to the circuit to be able to read the pic device? i am using mplab icd 2. the board was given to me like that to recover that code, but because pin 2 is missing, the mplab icd 2 reads a lack of power from the pic device. i have attached the schematic of the programming connector (VCC=24V it powers the entire board, and CR1 is a ceramic resonator) thanks everyone!
    Can't an ICD 2 be set to not supply the target board?
    Wink
    From ICD2 Manual note on P 11 : Pin 2 of the ICD2 MUST see a voltage ...
    so, you must choose the " POwer supplied to the target option" of your ICD2 ( in MPLAB )
    Now, I suppose your board supplies 5 v to the PIC ... The ICD2 will supply 5 volts to the target ...
    No danger to fry PGC or PGD pins ....
    Feb 2009
    i have set the mplab to not supply power to the target, and it still it doesn't recognize it. i was told that it could be because, whether i choose for the mplab to power the target or not, is through pin 2 that the mplab recognizes the target as being powered. so, because that pin is missing, even though the target is properly powered, the mplab keeps sending errors ( when i connect the mplab to the target, and the target is powered by an external source this is what appears on the screen:
    Connecting to MPLAB ICD 2
    ...Connected
    Setting Vdd source to target
    ICDWarn0020: Invalid target device id (expected=0x4D, read=0x0)
    ...Reading ICD Product ID
    Running ICD Self Test
    ... Failed Self Test. See ICD2 Settings (status tab) for details.
    MPLAB ICD 2 Ready
    Feb 2009
    i forgot, when i use the configuration i mentioned before (connecting mplab to the board via usb and powering the target with an external source). these are the power settings i get:
    target vdd: 0.00
    target vpp: 12.46
    mplab icd 2 vpp: 12.46
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  3. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  4. Problems with 16F876 on interrupts an WRITE / READ
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 20th December 2005, 15:38
  5. Having problems? REAd this thread - often!
    By Dwayne in forum Off Topic
    Last Post: - 26th July 2005, 16:19
