Help with ADC conversion
Results 1 to 7 of 7
Threaded View
  1. #3
    If the voltage threshold is a single fixed value, I would use an comparator interrupt with some basic filtering on the Voltage comparator input. This way you can do whatever you want during the time an Low-Voltage Alarm occur.
    Still possible to use a Timer Based ADC reading... but you need to consider the ADC sampling time + Timer interrupt time in your latency.. so maybe not as this "almost instantly"
    Another possible solution... use a zero-cross interrupt and read the voltage at ~0.707Vmax... not yet "almost instantly" either.
  1. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 15:33
  2. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  3. ADC conversion trouble
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 30th April 2008, 20:42
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 21:22
  5. ADC problem
    By NacNud in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 02:27
