Help with ADC conversion
Results 1 to 7 of 7
    Oct 2008
    Default Help with ADC conversion
    I am wanting to monitor the voltage output of a full wave bridge rectifier and determine when the RMS voltage drops below a certain value. I don't want to filter the "humps" because I want to know almost instantly when the voltage drops and stays low for a certain period of time. I don't have any code yet as I am still just thinking about how it can be done. Does anyone have any ideas or point me toward a thread that has covered this?
    Thanks, Don
    Omaha, Nebraska USA
    A possible starting point would be:
    1. Use peak values. Set your minimum (~1.42xRMS) in software, perhaps as a constant.
    2. Use a voltage divider to give you a sample output, calculated to give a maximum which does not exceed 5V. Total series resistance of the divider will depend on the output voltage of your bridge and the current through the divider, but it doesn't need to draw even as much as a milliamp--possibly even 100 microamps would do.
    3. With an ADC port, repeatedly sample the voltage from the divider for half the period of the bridge input. (How many times depends on the precision you require.) For instance, if the input is 60 Hz, the period is 16.7 ms, so an 8.4 ms sample would do it. Or, if your processor isn't doing much of anything else, just sample continuously.
    4. Continue to sample as needed, and compare the maximum value from any given sample to the minimum you have established as a limit. When it drops below the minimum you've set, record for how many consecutive sampling cycles the value stays below.
    One note: If the output from the bridge is filtered, you'll need to put a diode between the output of the bridge and any filtering (e.g., a capacitor) and place the voltage divider ahead of that diode.
    This is off the top of my head (or "shooting from the hip").
    I'm sure there will be other suggestions, better, simpler, or both.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    If the voltage threshold is a single fixed value, I would use an comparator interrupt with some basic filtering on the Voltage comparator input. This way you can do whatever you want during the time an Low-Voltage Alarm occur.
    Still possible to use a Timer Based ADC reading... but you need to consider the ADC sampling time + Timer interrupt time in your latency.. so maybe not as this "almost instantly"
    Another possible solution... use a zero-cross interrupt and read the voltage at ~0.707Vmax... not yet "almost instantly" either.
    I'll second the Comparator idea, but with a little difference. (Don't filter the signal)
    Set a timer to have a delay of 20ms or more.
    Using the comparator Interrupts, reload that timer every time you get a pulse.
    If the voltage drops below the comparator's trigger point, the timer will overflow.
    Use the timer interrupt/flag to determine when there's an error condition
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3162&stc=1&d=123345227 4" />
    Oct 2008
    Darrel, Mister_E
    I am not very familiar with comparators and the use of timers. I have been trying to read more about how to implement them. But this is what I think I need to do. Feed signal into CCP1 pin (after setting up compare module) on say an 18F1320. Set timer1 to reset after every pulse (half cycle ~8ms) by using comparator interrupt flag. If interrupt flag is not set (voltage below threshhold), timer overflows and sets overflow flag. If this is correct, what I don't understand is where the reference voltage (comparator's trigger point)to determine a low voltage condition comes from. Its probably pretty simple but I haven't grasped it yet.
    Thanks for the help,
    Don
    Edit:
    After reading the datasheet again and again and again..... I think I may not have a clue what you guys are trying to tell me...
    That will be hard to setup PIC18F1320 analog comparator, as he don't have any BUT... PIC18F2220 and lots other have some already built-in.
    Internal analog comparator works as regular voltage comparator (LM393 and so on), you set a voltage reference on one input pin (voltage divider, trim pot, whatever else fancy stuff), and you apply your signal on the other input pin, then you just monitor the voltage comparator output.
    In a PIC, when the output of the comparator change, it can trigger an interrupt event, so it's done in background. Once in the Interrupt handler, you do what you need to do.
    Have a look at Darrel's Instant interrupt, this will save you some headaches. There's also some code-example on how to use'em with Timer.
    http://www.pbpgroup.com/modules/wfse...p?articleid=19
    From there, you should be able to begin some experiments.
  1. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  2. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  3. ADC conversion trouble
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 30th April 2008, 21:42
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
  5. ADC problem
    By NacNud in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 03:27
