PIC - PIC Comm
Results 1 to 9 of 9
Thread: PIC - PIC Comm
    Feb 2009
    Default PIC - PIC Comm
    I've been working on a little robot project in PIC Pro Basic.
    I'm trying to establish some sort of communication between two PIC Microprocessors. 1 being a PIC16F84A with a keypad, the other a PIC16F877A controling the robot.
    The PIC16F84A scans the kaypad and stores the key pressed into a variable. The PIC16F877A needs to recieve this value and store it in its own variable.
    I've experimented with RS232 (SERIN, SEROUT) but I jus can't seem to get it working. There is 1 meter of cable between the two pics so could that be the reason?
    Any suggestions as to what I can do to achieve communication between these two pics?
    Try one thing first.
    Connect your PIC16F84 to your PC and send some data to any terminal softare (hyperterminal, TeraTerm, RealTerm, Microcode Serial communicator) and see if you receive any data.
    do the same but From your PC to your 16F877,
    once both work, try your PIC to PIC communication on small distance, then move on with long cable run. You may want to use RS232 driver for longer run.
    Quote Originally Posted by dgcarter View Post
    Hello dgcarter, and welcome.
    Since this is your first post, we know nothing about you, so I must ask, is this your first project, or do you have some experience? Have you tried the basic blinking LED yet? 1 meter should work easily, so if you would post your code using the code tags as shown in Mister_e's signature, (shown in green) let's get started.
    Feb 2009
    Hello again...
    I've been using PBP for a while now, I've blinked many many LED's, Swiched lights on and off with my PC and a PIC via RS232, and now I have a robot which follows a black line.
    Essentially I have a PIC 16F84A on a 4x3 keypad, I've tried getting it to communicate via RS232 with my Robot (PIC16F877).
    Heres the Keypads code...
    INCLUDE "modedefs.bas"
    ' Declare Variables...
    Col1      VAR PORTA.0
    Col2      VAR PORTA.1
    Col3      VAR PORTA.2
    Row1      VAR PORTB.4
    Row2      VAR PORTB.5
    Row3      VAR PORTB.6
    Row4      VAR PORTB.7
    LED       var PORTB.1
    SERTX     var PORTB.2
    SERoK     var PORTB.3
    Key       var word
    ' Setup Ports
    input row1 : input row2 : input row3 : input row4
    output col1 : output col2 : output col3 : output SERTX
    ' Setup Var
    key  = 20
    ' Program Start
    Boot:
        high led
        low led
        high led
        low led
        pause 2000
        high serok
        gosub ScanKeys
        if key != 20 then gosub transmit
    ScanKeys:
        high col1
        pause 50
            if row1 = 1 then Key = 1
            if row2 = 1 then Key = 4
            if row3 = 1 then Key = 7
            if row4 = 1 then Key = 10
        low col1
        high col2
        pause 50
            if row1 = 1 then Key = 2
            if row2 = 1 then Key = 5
            if row3 = 1 then Key = 8
            if row4 = 1 then Key = 0
        low col2
        high col3
        pause 50
            if row1 = 1 then Key = 3
            if row2 = 1 then Key = 6
            if row3 = 1 then Key = 9
            if row4 = 1 then Key = 11
        low col3
    Transmit:
        gosub flash
        serout sertx,4,[55,key]
        pause 50
        key = 20
        low led
    Flash:
        high led
        pause 50
        low led
        pause 50
        high led
        pause 50
    Ok, so the PIC16F84A raises SERoK to logic 1 which tells the PIC16F877A to accept serial communication.
    PIC16F877A Code:
    Define    LCD_DREG     PORTA
    Define    LCD_DBIT     0
    Define    LCD_RSREG    PORTA
    Define    LCD_RSBIT    4
    Define    LCD_EREG     PORTA
    Define    LCD_EBIT     5
    DEFINE    LCD_LINES    4
    'Define Aliases
    RHF       var          PORTB.0
    RHB       VAR          PORTB.1
    LHF       VAR          PORTB.2
    LHB       VAR          PORTB.3
    LineCom   var          PORTB.4
    LEDS      var          PORTB.5
    SERoK     var          PORTB.7
    SERRX     var          PORTB.6
    'Define Vars
    Dat       var          byte
    ADCON1 = 7
    'Begin program
    Boot:
        dat = 20
        Pause 500       ' Wait for LCD to startup
        gosub display
        low leds
        repeat
            Lcdout $FE, $C0, "!! Insert Ctrl !!"
            Lcdout $FE, $94, "Waiting..."
        until serok = 1
        goto modeselect
    ModeSelect:
        Lcdout $FE, $C0, "!! Select Mode !!"
        serin SERRX,4,[55],Dat
        pause 50
    Discon:
        Lcdout $FE, $94, "Pls Discon..."
        if serok = 0 then GoMode
        goto discon
    GoMode:
        if dat <> 20 then
        select case dat
            case 20
                goto boot
            case 2
                goto linefollow
        end select
    goto boot
    Display:
       Lcdout $fe, 1   ' Clear LCD screen
       Lcdout "PIC-Bot... v1.0"
       Lcdout $FE, $94, "Pls Wait..."
       Pause  1000
    'Check for controler
    ChkCtrl:
    if serok = 1 then modeselect
    'Line Follow loop
    LineFollow:
        Lcdout $FE, $C0, "~~ LiNe FoLlOw ~~"
        Lcdout $FE, $94, "...Scan Line..."
        low RHF
        low LHF
        PWM LHF,60,18
        if linecom = 0 then gosub moveleft
        low RHF
        low LHF
        PWM RHF,60,18
        if linecom = 0 then gosub moveright
        gosub chkctrl
        goto linefollow
    MoveLeft:
        Lcdout $FE, $94, "Correct Left"
        repeat
            low RHF
            low LHF
            PWM RHF,60,20
            PWM LHb,60,20
        until linecom = 1
        pause 50
        low RHF
        low LHF
        PWM RHF,60,18
    MoveRight:
        Lcdout $FE, $94, "Correct Right"
        repeat
            low RHF
            low LHF
            PWM LHF,60,20
            PWM rHb,60,20
        until linecom = 1
        pause 50
        low RHF
        low LHF
        PWM LHF,60,18
    Now the Robot waits until the keypad unit is pluged in, then it waits until the digit 2 is sent serially (by pressing 2 on the keypad), then it askes you to dicconnect the keypad unit (SERoK changes from logic 1 to logic 0) and it executes the program IF 2 was pressed.
    When a PIC have a built-in USART use it.. PIC16F877A have it, switch to HSERIN
    SEROUT on one side
    HSERIN on the other side
    Begin with it, then add some sugar around...
    Feb 2009
    SEROUT on one side
    I assume then I use PIN 26, labled RX on the PIC?
    yes indeed, and you may need to add some DEFINEs at the top of your code as well.
    Well, by default @4MHz it's already set @2400 baud, so... humm... you may not need any Define at all... it's just good programming
  1. Pic to pic interrupt ans serial comm
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 10th May 2008, 22:43
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 21:55
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. Comm example: Pic to Pic
    By Chadhammer in forum Code Examples
    Last Post: - 14th November 2006, 23:26
