Write to EEPROM timing, 12F683
Results 1 to 7 of 7
    Omaha, Nebraska USA
    Default Write to EEPROM timing, 12F683
    Okay, gang:
    My 12F683 data sheet (p. 122) gives EEPROM erase/write cycle time as 5 ms (typical) to 6 ms (maximum).
    My old PBP manual (p. 160) says, "Each WRITE is self-timed and takes about 10 milliseconds to execute . . . " (italics mine)
    My new PBP manual (p. 162) says, "Each WRITE is self-timed and takes up to 10 milliseconds to execute . . . " (italics mine)
    Whom should I believe/trust on this, and why?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Quote Originally Posted by RussMartin View Post
    I believe the first one (datasheet).
    The second one is a little ify.
    Depends on your tolerance of "about 10ms".
    An 18F4550 only takes 4ms.
    The third one is definately wrong, because the 16F84 can take up to 20ms, although it's usually 10.
    I think the best information will always be the datasheet for the particular device being used.
    Wink technology progresses ...
    Hi, Russ
    Have a Happy new Year ... and plenty of readers.
    a little trip through the datasheets I have shows for parameter "D 133"
    12 F 683 : 2 - 2.5 ms ( last edition ...)
    16 C 84a : typ 10 ms
    16 F 84a : 4 - 8 ms
    16 F 877 : 4 - 8 ms
    16 F 88 : 2 - 4 ms
    16 F 88x : 2 - 2.5 ms
    18 F 1320 : typ 2ms
    18 F 8723 : typ 2.5 ms
    18 F 4523 : typ 4 ms
    so ... it seems a factor of process method ... or chip generation.
    That also stick to what you've read in the different manuals ... for the date they have been written ...
    Hey Alain, try parameter D122
    Talking
    LOL ... seems EEPROM just need ~ twice the program memory time ...
    Omaha, Nebraska USA
    Thanks, guys.
    I suspected that the data sheet provided the information to actually rely upon, but . . .
    When compiling from a high-level language, one doesn't necessarily know how the compiler's designers accomplish a given command and whether or not their implementation of the command has somehow added drastically to the overhead.
    Russ
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
